Sully2 said:The wind blew and the....oh well..we all know how that story goes too!!!
Jump in your car and drive up to Cleveland and I will be happy to introduce him to you. Or just bite me.
I am sorry you dont have a tig some things are just to much sorrow to bear. Actually to me that is not a big loss. I have tried using a tig and did not really like it. Hopefully the easter bunny will bring you a synchrowave 400 one of these days.john_bud said:Back on topic,
The mig may (just may) do the 1/4". Plan on multiple passes and pre-heat the area as much as you can. That will help even if it's just a propane torch.
Proud owner of a Lincoln 255 amp mig with 70% duty cycle at max output. Not quite so proud (former) owner of a 120v Harbor Freight mig. The typical 85-100 amp 120 v mig is geared to sheet metal and up to 1/8" in short bursts. Mine would still weld, but they started looking like bird dookie.
Back off topic - typical guy, that has a tractor, will have a larger set of tools than the typical suburban 1/8 acre lot dweller. Easy to get a case of undie-bunchie when you forget to define the target population. "Typical" depends on who you are talking to. Of my group, I have one of the smaller migs. And (sob) no TIG. Oh the humanity!
jb
Mundy said:With my welder I am mindful of the duty cycle. Mine is 40% at 90amp and 20% at 135amp. That means at 90amp 4 minutes of welding and 6 minutes of machine idle.
gemini5362 said:AS far as welders go. Most of the guys I work with have migs. We have a pretty good paying job for our area and do not mind the extra dollars. Having tried welding with a stick and being tired of being laughed at I love my mig. I think the duty cycle arguement is winding up like comparring apples to oranges and to grapes and to plums. A lot of people are using their own experience for their comments and everyone has a different definition of things. Continuous welding. to some like ray that might be for half an hour or an hour or longer. To me a continuous weld is about 15 minutes. To some of us a 300 am mig machine ( oh lord wont you buy me a really big migis what the average person has at home. To some of us the 89.95 110 volt mig is the average machine. Even though we are in disagreement we all might be in agreement if we used the same definitions. I personally have a miller DVI that is a dual voltage machine that has 175 amps max with 220 volts input power. If you look at the duty cycle at max amperage it is something like 40 per cent and might even be as low as 20 per cent. However when you look at the chart in the 140 to 150 amp range all of a sudden it jumps to over 90 per cent. I very very very rarely weld anything big enough to put the selector in max range. Usually I run it about 3 or 4 positions down from max so I figure I an in the 90 per cent plus range. I have never had it shut down on me. Which welder is better is so much a personal preference. I think part of the preference for the guys that have been welding for decades is that they are used to stick welders. To them striking an arc and running a bead is so second nature that they dont even think about it. To me being able to pick up the torch stick it next to the metal and pull the trigger is a lot more user friendly. stick machines are a lot cheaper and a lot easier to find used ones that is for sure. I think my DVI with all the bells and whistles was about 2000.00 but of course my wife made some salesmans day. She went in and said my husband wants a miller DVI I want to get everything he needs to go with it. I almost choked when she brought it out on christmas day. There was the DVI and the spool gun and the dual bottle cart etc etc. I am not complaining and If I ever need to weld aluminum or stainless I am ready
The other big different I see with stick is elctode lead length. You can run 100 foot of cable out to the electode holder with a stick and no problem it is a bit of money but that is all. I could not imagine getting a 100 foot torch for a mig. Either one works fine for someone and for some lucky skillful people they both work well.
plastikosmd said:... finally, regarding stick..the process itself does not require more 'power,' rather the type of machine (transformer/inverter etc), inverters for stick and tig require much less power input for the same amp. machine without loss of duty cycle and at sigificant weight advantage.
