When you say "continious" do you mean that once the arc starts..it doesnt stop AT ALL..for ANY REASON for a full 15 minutes? I cant sit or stand in the same exact spot for 15 minutes...and once you let off the trigger..or stop to change electrodes with a stick machine...the clock starts all over again!!
Whereas you CAN extend the length of cable to the stinger holder..its mucho better to extend the "AC" to the machine itself..i.e. an extension cord.....same deal with a wire fed machine. You cant feed wire thru a 100 ft long torch cable...15 feet is a long way to do it...you use a large extension cord.
I started out with NO welder..of any sort. Tried AC stick welders many times and only accomplished sticking the rods. Had I been given the chance to use a DC stick machine I MAY HAVE bought one of those in the beginning instead of my HH140 (110V machine) that I practiced on.
After going to night school for welding I found it MUCH easier to weld using a larger machine turned DOWN than a smaller machine running "wide open"...hence my purchase of the HH210. But in eaither case I find it LOTS MORE easy to control my electrode when its mere inches from my control hand...than to control the arc when its at the end of a 14" long stick!!!
Lets not forget the AMPERAGE requirements of both machines. I can run ( per Hobarts specifications) a 210 MIG machine wide open..on a circuit controlled by a 30 amp breaker and wired with 12 ga wire ( per their specs now) Try that sort of thing with a 225 amp stick machine and either the breaker would pop on you every few minutes or ( lets hope not) you would smoke the circuit wiring. Stick machines REQUIRE lots more "power"...in fact the Hobart 225 machines require a 50 amp breaker. My little outdoor shop thats 10 x 14, only has 60 amp service to it because thats all I could tap off the main panel!!
