welding cast housing?
   / welding cast housing? #32
If you end up welding these parts, one trick that I have used in the past is to use a needle scaller to peen the welds after each pass or deposit. And I mean a heavy peen. This acts as mechanical stress relieving process. It will minimize distortion. Later.
   / welding cast housing? #33
We have a very good recycler here in AB, They ship all over North America . Gratton Coulee Agri Parts Ltd ph: 780 754 2303 They are located in Irma Alberta. Lots of Stock
   / welding cast housing? #34
I have had good luck with nickel rod, but as it has been stated above , u must be meticoulous in your procedure.
   / welding cast housing? #35
I have had 3 of these units they are notorious for this issue I have split all 3 tractors and have had the housings welded costing about 1000-1900 depenfding on how bad the welds were. All worked after and held up as good as the original factory garbage. You abosolutely have to find a welder with the knowledge and capabilities to weld cast iron, this process is a heating then welding heating then welding laborious painstaking process so that there are no bad sections of the weld. It can be done it is cheaper than a replacement housing and John Deere are crooks for putting out such a substandard product I know of at lease 50 of these tabs myself that have had the issue. They should at least pat for housing but they refuse as they slip under the guise that the loader bolts loosen on this machine and as part of preventative maintenance one should keep them tight just like greasing the machine before use. Unfortunately no-one tele you that when yo buy one nor anywhere else other than trial n error or finding out the hard way after the machine splits, you will probably have to check the input splint o the hydrostatic drive pump as when these crack it makes an uneven parallel in the tractor and th only part holding things together is the pump where it connect into the motor. this usually bends or breaks either way if you fix without addressing that issue you will have more problems later.
2016 CATERPILLAR 950M WHEEL LOADER (A52705)
2016 CATERPILLAR...
TORO TRX-20 WALK BEHIND TRENCHER (A51406)
TORO TRX-20 WALK...
2006 Chevrolet Express 3500 Versalift Vantel29N 29ft Bucket Van (A55788)
2006 Chevrolet...
UNUSED 70PCS Black Metal Roof Panels (A53117)
UNUSED 70PCS Black...
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2016 Peterbilt 320...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
