Welding Cast Iron to regular steel
   / Welding Cast Iron to regular steel #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
OK, lots of things going on for me over the next few weeks. I am making a sculpture, maybe, hopefully. and I need to weld some bearings onto the steel (4x4 sqaure to maybe something like this 3/4" 2 BOLT FLANGE BEARING W/LOCK COLLAR)
Anyway, Can I do this? I saw Chuckee Using 7018 with good success and limited prep. Might follow that but wanted to look at maybe Mig Welding this? Or is there a bearing that is weldable and not cast iron?
Thoughts? Suggestions?
   / Welding Cast Iron to regular steel #2
I've done it. It has poor strength, but it did stick together
   / Welding Cast Iron to regular steel #3
Use a pure nickel rod,, plenty of ductility in the weld,, almost never cracks.
   / Welding Cast Iron to regular steel #4
Sculpture?? How strong do you need it to be?
   / Welding Cast Iron to regular steel #5
Right on. I stick weld cast iron to regular steel (A36) using Super Missileweld Rod (1/8" rod, DC+, 100-120 amps). Works fine.
Good luck.
   / Welding Cast Iron to regular steel #7
Super Missileweld is a high tensile rod but not a nickel rod. Check with a bearing supply, you might find a pressed steel bearing mount.
   / Welding Cast Iron to regular steel #8
Could it be brazed?
   / Welding Cast Iron to regular steel #10
preheat the cast material, well with mig, post heat and let cool slowly. I like to lay the welded piece on top of my hot wood stove to let it cool as the fire burns out.
2020 AMCO F42B-3626CS 13ft Pull-Behind Disc Offset Harrow Tiller (A49461)
2020 AMCO...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2000 INTERNATIONAL 4300 17FT ROLLBACK TRUCK (A51222)
2000 INTERNATIONAL...
2005 Chevrolet C4500 Altec Bucket Truck (A50323)
2005 Chevrolet...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2017 AUTOCAR YARD SPOTTER (A51222)
2017 AUTOCAR YARD...
