Welding Cast Iron to regular steel
   / Welding Cast Iron to regular steel #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
OK, lots of things going on for me over the next few weeks. I am making a sculpture, maybe, hopefully. and I need to weld some bearings onto the steel (4x4 sqaure to maybe something like this 3/4" 2 BOLT FLANGE BEARING W/LOCK COLLAR)
Anyway, Can I do this? I saw Chuckee Using 7018 with good success and limited prep. Might follow that but wanted to look at maybe Mig Welding this? Or is there a bearing that is weldable and not cast iron?
Thoughts? Suggestions?
   / Welding Cast Iron to regular steel #2
I've done it. It has poor strength, but it did stick together
   / Welding Cast Iron to regular steel #3
Use a pure nickel rod,, plenty of ductility in the weld,, almost never cracks.
   / Welding Cast Iron to regular steel #4
Sculpture?? How strong do you need it to be?
   / Welding Cast Iron to regular steel #5
Right on. I stick weld cast iron to regular steel (A36) using Super Missileweld Rod (1/8" rod, DC+, 100-120 amps). Works fine.
Good luck.
   / Welding Cast Iron to regular steel #7
Super Missileweld is a high tensile rod but not a nickel rod. Check with a bearing supply, you might find a pressed steel bearing mount.
   / Welding Cast Iron to regular steel #8
Could it be brazed?
   / Welding Cast Iron to regular steel #10
preheat the cast material, well with mig, post heat and let cool slowly. I like to lay the welded piece on top of my hot wood stove to let it cool as the fire burns out.
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2018 FREIGHTLINER...
2020 INTERNATIONAL LT625 TRI AXLE SLEEPER (A54607)
2020 INTERNATIONAL...
70pc 12ft.x 3ft. White Metal Roof Panels (A53424)
70pc 12ft.x 3ft...
2008 CATERPILLAR M322D MOBILE EXCAVATOR (A51406)
2008 CATERPILLAR...
CASE TV370B SKID STEER (A52705)
CASE TV370B SKID...
SCAN TO RECEIVE TEXT UPDATES (A54757)
SCAN TO RECEIVE...
