Welding???
/ Welding??? #21
You made the right decision to replac eit. Good luck with the backhoe. Wish I had one for mine, someday maybe.
/ Welding??? #22
wgbiii said:
Thanks for all the replys. I broke it because I did not do a quick inspection of the 3 pt hitch assembly. I had found a pin when I was taking off my mower and wrongly assumed it was the one I had lost the previous week. The upper pin came out and when I was backing up the lower arm dug into the ground and "pop" goes the casting. As I pilot I always do a preflight of an airplane. Now I know I should do the same on my tractor.
I'm going ahead and replacing the axle housing as I have been quoted $200 or $300 for the part and 3 hours labor. I am getting a used backhoe installed at the same time. ($5000 for a JD 48).
Thanks again,
Will
PS: Don't forget to take a quick look at your pins so you don't end up out $500 or more. Lesson learned.
Tractors...airplanes thay are equipment that require a walk around inspection before going to work/play.
I'm sure that will be the last time you forget your walk around inspectcion before gettin all comfy in the seat.
/ Welding??? #23
I think you are doing the right thing. Any time the repair is approaching 2/3 of the 'repalce' cost.. the replacement starts becoming the better deal.
Cast iron repairs are best left to 'non stress' areas. or for parts that are otherwise irreplaceable.. and you have nothing to loose by trying to repair them.
Your axle trumpet doesn't fit these categories.
Soundguy
Thanks again,
Will
/ Welding??? #25
What part are you refering to?
No quoted message to refer back to..?
Soundguy
/ Welding??? #26
wgbiii said:
Please help!!!! I have a JD 4400 in which I have broken the casting for the 3 pt hitch on the frame. Can this be successfully welded? I'm not sure if it is cast iron or cast steel.
This casting is aluminum on my 4310
/ Welding??? #28
Wow.. an aluminum frame for the 3pt... Hope it is thick stuff.
Soundguy
/ Welding??? #29
Yes, aluminum. I was concerned/perplexed when I noticed this part was aluminum because cast iron intuitively seems like a better material for this application, especially when one considers that cast iron would lower and move back the center-of-gravity. My 4310 is stictly a loader tractor (at present), so all that is on my 3ph is a 1000# ballast box. I'm guessing that cast aluminum is more expensive than cast iron, so JD must have had a good reason for going with AL. Heat transfer?
/ Welding??? #30
More than likely an overall weight issue on the tractor. I wonder what the load limit is on an aluminum housing versus a cast iron housing?
2007 MACK CTP713 TRI AXLE DUMP TRUCK (A59575)
2007 MACK CTP713...
2015 JOHN DEERE 1050K WH CRAWLER DOZER (A52707)
2015 JOHN DEERE...
Case Titan 3530 (A61307)
Case Titan 3530...
2018 International DuraStar 4300 2,000 Gallon Water Truck (A59230)
2018 International...
1996 Freightliner FLD112SD T/A Dump Truck (A55852)
1996 Freightliner...
Bobcat MT85 (A60462)
