Welding???
/ Welding??? #31
I wonder if there is a similar tractor with similar rear housing in CI that you could compair weight specs / lift specs to?
My first guess is this was a bean counter move.. I.E., they figured what it should carry.. reversed engineered the system to only carry that weight.. saved 3 cents in overall cost, and in the end, left the tractor design with a working lift casting that is up to 'specs'... but doesn't exceede them, like a ci casting 'might'.
There may also be other variables.. like thickness.. and heat disipation..e tc.
IMHO.. I'd want iron or steel back there.... I work with heavy equipment every day.. and none of our big yellow equipment is using aluminum castings in weight bearing members.. though quite a few gear cases covers are cast aluminum.. while the transfer cases themselves are CI.. etc.
Soundguy
Soundguy
/ Welding??? #32
One thought.. If it was aluminum.. I think it would have a much better chance at being welded back together than CI... etc..
Soundguy
JimR said:
More than likely an overall weight issue on the tractor. I wonder what the load limit is on an aluminum housing versus a cast iron housing?
UNKNOWN  SKIDDED FRAC TANK (A58214)
UNKNOWN SKIDDED...
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
2019 MACK PINNACLE (A55745)
2019 MACK PINNACLE...
John Deere 5055E (A53317)
John Deere 5055E...
2013 Ram 5500 Bucket Truck, VIN # 3C7WRNALXDG552597 (A61165)
2013 Ram 5500...
2007 Barber 600HD 76in. S/A Towable Beach Rake (A59228)
2007 Barber 600HD...
