Carl_NH
Elite Member
- Joined
- Apr 5, 2002
- Messages
- 3,782
- Location
- Coastal NH
- Tractor
- 01 Kubota B21TLB, 2010 Ferris 52" ZTR, Cub Cadet 1811, Gravely Super8
Place a 55 gallon drum on its side against the well casing and hold it tight with a couple of T post.
Tie the poly pipe to a 4 wheeler and pull slow.
My pump is about 225' down and it worked perfect, no problems. I replaced the wire and the problem was fixed
Scott,
Great idea and good for those of us that have a tractor or unit to pull. The drum or roller (I am thinking my lawn roller) would work very well to keep the pipe from chafing. Depends on the height of the steel casing above ground (mine is 24") but a little bit of on site "engineering" would solve this - great idea - thanks for sharing. Our well is 400' and the pump is at 380' so not one that you can pull by hand..
Carl
Scott,
Carl
