What attachment would you use ?
   / What attachment would you use ? #11
   / What attachment would you use ? #14
I use a 10 hp little wonder blower strapped in the loader bucket of a bx 24 . I would cut the **** thing down but it gives shade on the house during the hottest part of the day .
   / What attachment would you use ? #15
I have a sweet gum ball problem. Has anyone had any luck raking or picking up these spiny balls with your tractor?
I am trying to find something that will at least get them into piles or wind rows, with tearing up the yard to much.
I thought may be a rock rake with the gauge wheels might do the trick. But before I buy one I thought I would get a second, third, or fourth opinion.
mike
You may want to look at something like these.
http://www.homedepot.com/catalog/productImages/400/2b/2b9ae9ac-c593-4f31-b57f-c038d4348425_400.jpg
http://www.nuts-about-pecans.com/images/pecan_picker_upper.jpg
https://images-na.ssl-images-amazon.com/images/I/81hzVcPLTuL._SL256_.jpg
If you search google images (nut gathering tool) you will find others.
I found your solution (besides the chainsaw). $50
The Nut Wizard Pick Up Nuts and Sweet Gumballs, Harvesting Pecans, Walnuts, Acorns
Watch the video. It seems to do a good job.
Thanks for all the Ideas,
BCP I have tried a blower it want dislodge them from the grass.
xfaxman I have thought about the pine straw rake , but I don't think it will be stiff enough to get them out of the grass . I have thought about making one with several rows of teeth.
moss road I may try the nut wizard although it looks like it will be hard to empty and may not hold very many. Right now I am only raking about 1/5 of the total area covered and I am raking up 4 big heaping wheelbarrow loads.
The Ace hardware thng is too small.
The bag-a-nut looks like it would really work and cover the area I need to cover, but I sure don't like the price for some thing with only one use .
Anyone think my rock rake idea with the gauge wheels set so the rake rides about 1/2 inch above the ground will work? That way I will have other uses for the piece of equipment .
   / What attachment would you use ? #17
A rock rake will be way too stiff for what you want to do even with the wheels. Unless the ground is super level and the tines barely touches the grass they will dig it out. We have property in the Texas Hill Country where the river on our property has a rock base. When water levels are low I take a tractor with the rock rake, drive into the river, and rake out yards and yards of gravel brought in by previous floods. The tines are really stiff and can pull out many hundreds of pounds of rocks at a time. Turf grass would be destroyed in my opinion. My rock rake weighs in at about 450 pounds and I would not want to drive my tractor over the lawn around the house with one of my tractors.
   / What attachment would you use ? #18
The proper attachment is a good sharp chainsaw. Prune your sweet gum trees about six inches up from the ground and use your tractor to haul them away.:D
I like to either prune them about waist high or real close to the ground. Waist high I know to go around them, ground level I roll over them.
Or, from this site...
The Best Method for Removing Sweetgum Balls From the Lawn | Home Guides | SF Gate
"Removing the tree permanently by cutting it down is the most effective solution for removing the sweetgum ball problem from your lawn, then following up by replacing it with a fruitless roundleaf sweetgum (Liquidambar styraciflua 菴*otundiloba? or another type of tree."
That must be the scientific approach.
After a judicial pruning I make them into shelves.
   / What attachment would you use ? #19
What about one of those big lawn vacs? My father in law used to have one for his leaves and it would pick up most everything.
   / What attachment would you use ? #20
I was just thinking about safely getting the tree down. Time to fool with the stump later. You could just put a big flower pot on it to mark it or cut it off again close after the tree is down. Another option is to throw an old truck rim over it and use it as a fire pit for the summer. Roast a few marsh-mellows and down a few cold ones while swapping stories over a nice fire and your stump will fade away. :drink:
Attention (A57148)
Attention (A57148)
2015 Freightliner 122SD T/A Wet Kit Day Cab Truck Tractor (A59230)
2015 Freightliner...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
13042tx (A55973)
13042tx (A55973)
2021 XCMG CV123PDU ROLLER (A60429)
2021 XCMG CV123PDU...
Aerway Tillage Tool (A59814)
Aerway Tillage...
