What attacment for making garden rows?
   / What attacment for making garden rows? #1
JRP
Platinum Member
South Texas
Kubota M6800
I have a new garden plowed with a sub soiler, middle buster, and disk. Now I need rows. What attachment works best?, or what are my options ?
My tractor is about 70 hp and is heavy. With the middle buster the tires leave big ruts. I was thinking of making a tool bar with a four shank something for making rows.
Also, what is a hipper and a cultipacker?
Thanks
JRP
   / What attacment for making garden rows? #2
A hipper is a row-disc that farmers use to sculp up rows after plowing. It just re-forms the rows. For each row, most have 2 sets of gangs. On each gang it has 2 blades that are at about 60-70 degree angle. Here's a Bigham Bros hipper used around your part:
Bigham Brothers Lilliston 6401 Disc Bedder
If your ground is disced well, the hipper will work just fine. We used to use our 6-row quite often. You will need to have quite a depth of soil loosened, or you'll just have to go over it a few times with the hipper.
   / What attacment for making garden rows? #3
I created a disc hiller by mounting big, 45 degree opposed discs on an old JD soil ripper diamond bar. Agri Supply has a similar frame and the discs to purchase. They call the frame a Keulavator.
Attached are pictures of mine.
My little 18.5 hp JD pulled these fine. Your bigger tractor may be a tad wide for doing a single row. Mine is great.
   / What attacment for making garden rows? #4
I had this same issue of making rows in my garden. After a few trys using my 3 point rake I gave up and went to Tractor Supply and bought one of these 3 point drag blades. The soil did need to be good and loose but it did a good job of making rows. I set the drag blade to a 45 degree angle. I got better at it as I went along.
Tractor Supply Company - 6 ft Rear Blade
   / What attacment for making garden rows? #5
Disc Ridgers
Heres a Link To A video of a Disc ridger.
Video Name- Video Making Rows using Hippers / Pick Up disc
Vegetable Garden Videos
   / What attacment for making garden rows? #6
Good videos, and probably exactly what the OP needed.
   / What attacment for making garden rows? #7
Thanks
JRP
Get your tool bar and your four shanks....go to your local farm supply store or to you local implement dealer....then buy furrowing shovels to bolt onto your shanks. I don't know which part of the country your from but that is how it is done out here.
You do know that you can buy any type of tools you need to bolt onto your shanks. Knives, shovels, etc..
Here is a picture of a John Deere Planter.....notice the shovels in front of the planter units.....that is what you can use to furrow out your garden.....now lets see if I can post the picture.....http://www.bakerauction.com/images/600_2-6F.JPG
   / What attacment for making garden rows? #8
Goggle disc hillers. These work on tractors of 35-40 hp or more like yours. Think they're a combo of a tiller plus some discs to raise the stirred up dirt into a raised row.
Ralph
   / What attacment for making garden rows? #9
I used one of these to make beds this weekend. It wasn't perfect but worked just enough.
   / What attacment for making garden rows? #10
FYI, a cultipacker is used to pack (or press) the seed down into the dirt, but not so deep that it won't sprout up quickly enough. If you're making rows, then I don't think a cultipacker will help you much. If you google them, you'll see what I mean by that. They are made to work mostly on just flat areas like a lawn or a food plot. You can get them in 5ft up 12ft widths I think.
John Deere 5055E (A53317)
John Deere 5055E...
2016 FORD TRANSIT 350 CARGO (A59575)
2016 FORD TRANSIT...
Peterbilt Tandem Axle Road Tractor (A47477)
Peterbilt Tandem...
John Deere 612C Corn Head (A59814)
John Deere 612C...
2000 Hyster S50FT (A55973)
2000 Hyster S50FT...
CAT D8 (A58214)
CAT D8 (A58214)
