What cause a tractor to lose forward and reverse?
   / What cause a tractor to lose forward and reverse? #11
If it was the clutch, the adjustment only takes hand tools. The cost of a manual is much less than a trip to the dealer. Ask the dealer if the tech can show you what he did to adjust it. Good to know for the next time!
jb
   / What cause a tractor to lose forward and reverse? #12
jb
   / What cause a tractor to lose forward and reverse? #13
Unless I am misunderstanding your post it's not the linkage. If it was out of adjustment the clutch wouldn't disengage meaning the clutch wont slip.If you can put it into gear and and it won't move it is either the clutch is gone or the trans. is broke.
   / What cause a tractor to lose forward and reverse? #14
</font><font color="blue" class="small">( Unless I am misunderstanding your post it's not the linkage. If it was out of adjustment the clutch wouldn't disengage meaning the clutch wont slip.If you can put it into gear and and it won't move it is either the clutch is gone or the trans. is broke. )</font>
It was the linkage. It is fixed now.
   / What cause a tractor to lose forward and reverse? #17
I'm c urious. Did they give you any explanaition as to why this happened all at once. I'm glad that is all it was.
   / What cause a tractor to lose forward and reverse? #18
They just said that they will wear out or come off on occasion. Apparently they wore out because they charged me for new parts. It cost me $535.
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A55301)
2016 KBH...
2016 Dodge Caravan Van (A53424)
2016 Dodge Caravan...
48" WIDE WOODEN STAIRCASE W/ METAL RAILING (A54757)
48" WIDE WOODEN...
2017 Nissan NV200 Cargo Van (A53422)
2017 Nissan NV200...
2017 FREIGHTLINER M2 106 (A53843)
2017 FREIGHTLINER...
Ford Pickup NR (A50323)
Ford Pickup NR...
