What cause a tractor to lose forward and reverse?
   / What cause a tractor to lose forward and reverse? #11
If it was the clutch, the adjustment only takes hand tools. The cost of a manual is much less than a trip to the dealer. Ask the dealer if the tech can show you what he did to adjust it. Good to know for the next time!
jb
   / What cause a tractor to lose forward and reverse? #12
jb
   / What cause a tractor to lose forward and reverse? #13
Unless I am misunderstanding your post it's not the linkage. If it was out of adjustment the clutch wouldn't disengage meaning the clutch wont slip.If you can put it into gear and and it won't move it is either the clutch is gone or the trans. is broke.
   / What cause a tractor to lose forward and reverse? #14
</font><font color="blue" class="small">( Unless I am misunderstanding your post it's not the linkage. If it was out of adjustment the clutch wouldn't disengage meaning the clutch wont slip.If you can put it into gear and and it won't move it is either the clutch is gone or the trans. is broke. )</font>
It was the linkage. It is fixed now.
   / What cause a tractor to lose forward and reverse? #17
I'm c urious. Did they give you any explanaition as to why this happened all at once. I'm glad that is all it was.
   / What cause a tractor to lose forward and reverse? #18
They just said that they will wear out or come off on occasion. Apparently they wore out because they charged me for new parts. It cost me $535.
2019 MACK PINNACLE P164T DAYCAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2019 TEREX PHOENIX 2100 TROMMEL SCREEN (A54607)
2019 TEREX PHOENIX...
1999-2010 Ford Pickup Truck Bed (A52377)
1999-2010 Ford...
2022 Kubota KX71-3S Mini Excavator (A52377)
2022 Kubota...
CAT D6C Crawler Dozer (A47477)
CAT D6C Crawler...
2000 Trail King TK70SA-48.2 T/A 43 Ton Hydraulic Slide Axle Step Deck Trailer (A52377)
2000 Trail King...
