What did you do to your tractor today?
   / What did you do to your tractor today? #61
What I did to my tractor today: fixed the broken drawbar hitch and bent rod. It got bent & broken trying to pull out a fully loaded 14 yard dump truck with a 3/8" chain. Actually broke the ears off the pin attachment point for the drawbar. I welded them back on, but have my doubts as to it holding much as the bracket appeared to be cast iron rather than cast steel. At least it didnt crack out when I welded it with 7018. That bent rod was a PIA to straighten. I picked the whole rear end of the tractor up with hydraulic jack centered on the V bend and didnt straighten it when cold. Had to heat it with a torch to get it straight enough to remove from the bracket then pound it with a 16# sledge hammer to finish straightening it.
LOOKS LIKE A VERY NICE WELD. I wish I could weld like that. My welds usually hold but just look awful!!
Put a bit of paint on the exhaust to finish it off.
Drained the oil out of the transmission and leaving it to drip all night.
Made two pins for the stablisers as they were missing.
Steamed off the back end ready for painting
   / What did you do to your tractor today? #63
good thread
   / What did you do to your tractor today? #64
Been painting the fenders and hood and misc. other sheet metal on my 1983 Kubota B6200. It's coming out mostly good for a backyard painter. (Actually in-the-garage-with-heaters-on painter.)
   / What did you do to your tractor today? #65
What I do to the tractor today - well after be inspired by those here and tired of putting the chain and chain saw in the bucket or BH bucket on my b21 I made a scabbord and mounted to the left frame. Also put a 7.62MM **** box for the chain.
The box has about 1" clearance for the hood and the chainsaw fits nicely too with 2" + clearance. I considered putting the scabbord on the FOPS but this is more out of the way and doesnt impact viewing either.
   / What did you do to your tractor today? #66
Nice job.
   / What did you do to your tractor today? #67
Thanks GP - dont have a welder ( yet) so this is plywood laminated setup serves the purpose.
I restored a L185DT with FEL and BH in 97-98 then bartered it for my barn build and got the B21.
Post some pics of your B6200 when you get a chance!
   / What did you do to your tractor today? #68
It's in pieces and parts right now lol.
I'll post some up soon.
Drat, I just sprayed the hood and it was going great, 90% done, when I got some splatter drops. I'll have to sand that when it dries and paint it again.
   / What did you do to your tractor today? #69
I replace the grill in my JD4720 today. Next weekend I will install my deluxe grill guard that's due in on Thursday. :(
What happened to the old one:)
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A52748)
2007 Freightliner...
2022 MACK GRANITE TANDEM AXLE DUMP TRUCK (A56129)
2022 MACK GRANITE...
Galvanized Livestock Wire Gate - 4FT x 11.5FT (A55301)
Galvanized...
John Deere 2640 2WD Tractor with 146 Front Loader (A55302)
John Deere 2640...
2014 Ford F-450 Dump Truck, VIN # 1FDTF4GT9EEA61310 (A54865)
2014 Ford F-450...
2006 KENWORTH T800 TANDEM SLEEPER TRUCK (A52141)
2006 KENWORTH T800...
