What did you do with your Chinese baby digger today?
   / What did you do with your Chinese baby digger today? #561
Do you find out when it falls out? Or are you checking it frequently?
Looks pretty accessible. Is your ring gear guard only partial coverage? Mine is like that.
No, it’s never fallen out, found during routine maintenance check. It’s very easy to access, no cover, just look up from underneath/rear of machine. Ring guard is as pictured, partially covered.
   / What did you do with your Chinese baby digger today? #562
Can the head be drilled and then safety wire it to something nearby? It can't back out if it can't turn.
That gear has to turn 360degrees foreword and reverse, don’t think a safety wire would work in this situation. I expect that the red loctite will do the trick.
   / What did you do with your Chinese baby digger today? #563
Meanwhile, the number of youtube user videos on these machines continues to increase. Mike Festiva's video of his machine shows safety wire factory installed on his unit (Rippa R319).
   / What did you do with your Chinese baby digger today? #564
Ours looks like yours, I'll start checking that bolt. Thanks.
   / What did you do with your Chinese baby digger today? #565
Good catch. If you lose or break the pinion gear, that is gonna be a Bad Day.
My recent cushion valve installation has made house rotation smoother. Highly recommended.
Some machines seem to have a full-coverage ring gear guard, and some, none at all.
Now I gotta go check the bolt for tightness.....
   / What did you do with your Chinese baby digger today? #566
never looked under either of mine. cant really get down under there.
still workin on tile fixins and got rained out,---afraid winter is here.
Great little backfiller,--- SO FAR! lol!
   / What did you do with your Chinese baby digger today? #567
There's a local contractor who installed the gas line for the local utility. That guy could really backfill quickly with the front bucket on his excavator. I don't think I've ever seen anybody else operate so quickly.
   / What did you do with your Chinese baby digger today? #568
Just bought the AGT 9 piece set of attachments for my 2 L-12's. no pix yet but got the so called quick tach put on. Interesting for sure! Grapple mounting looks like you have to strip the whole end off the boom to mount it and that was what I wanted the most so one of the 12's might just be grapple unit and nothing else. jury still out on that one. Dont need post hole diggers but one came in the package. The bucket assortment and ripper is what I was after.
   / What did you do with your Chinese baby digger today? #569
I use the quick attachment too, works pretty well, however I do not have the grapple attachment. I do have a grapple for my tractor which I love. I will say the quick attach pins are showing wear after 40hrs. Of pretty hard use. It’s something I need to look into sooner rather than later. I do grease regularly, just about before every use.
   / What did you do with your Chinese baby digger today? #570
pic. of the pallet of the attachments minus the "quick" hitch which I put on the newest L-12.
Diggin on another tile line.---had to uncover the old clay tile and remove it then straddle the ditch and go deeper to be on grade for the new tile.
Been runnin 4' deep with it and so far it digs fine. Gotta grease the digger before I start today then go again.
2021 KUBOTA SSV75 SKID STEER (A52707)
2021 KUBOTA SSV75...
Informational Lot - Financing (A57024)
Informational Lot...
2013 PETERBILT 389 (INOPERABLE) (A55745)
2013 PETERBILT 389...
2017 E-Z Beever M12R Towable Brush Chipper (A50322)
2017 E-Z Beever...
(APPROX 23) 2" X 2" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 23) 2" X...
JOHN DEERE 410L BACKHOE (A52706)
JOHN DEERE 410L...
