What do your water temps look like?
   / What do your water temps look like? #11
I have the L2350 . Only have a tach/hour meter. I would like to add the oil & water temp gauge. Especially the temp gauge. I wouldn't have a problem mounting them but where do you connect the water thermocouple on the engine and also the oil pressure sensor ? Pic's would be really helpful !
   / What do your water temps look like? #12
WEll for the life of me I can't locate the pictures of the stuff, so I'll describe....
Oil Pressure - just a regular auto parts oil pressure gauge. Your tractor is like mine, it does have a oil pressure idiot light, you can tap in where that pressure sensor is. While sitting on the tractor, on the left side of the enighe, near the back above the starter. You will see a 1 1/8" or so hex plug screwed into the block, there will be a single spade connection comming from the center. Just a single wire connected to this. Take this out, get some brass T fittings or something to add the oil pressure line that will run to the gauge. The small pipe thread is standard us 1/8" pipe thread.
For the temp gauge I went with the standard Kubota set up because the sensor is the one for my engine. The gauge and sensor I bought from TractorSmart.com. While sitting on the tractor, on the back right side of the cylinder head, there is a plug where the sensor goes. You remove this plug and screw in the brass sensor. The plug is right next to a head bolt and injector. You should be able to tell which is which. From there you need to tap into a hot wire when the key is on, then the single wire from the sensor to the gauge. The gauge is marked + - S if I recall.
Wait, found the pics. First is the temp sender, you can see the yellow wire and red connector at the back of the head.
The oil sender, you can see the crass fitting in the far left sode if the picture. Then the plastic line wrapped around the large wiring harness....
Another shot, you can see the shinny brass fitting just abouve the starter, the round/hex thing just in front of it is the oil pressure idiot light sensor. Looking at the top of the engine you can see the yellow temp sensor wire going into the back of the head.
BTW, the red wired going to and from the alternator are the ones I used for the amp gauge.
Good Luck!
Good Luck!
2012 New Holland BR7070 Round Baler with XtraSweep and Net Wrap (A57024)
2012 New Holland...
toro turf sweeper (A50324)
toro turf sweeper...
2008 Freightliner B2 School Bus (A55852)
2008 Freightliner...
1961 International C120 Pickup 4x4 (A54865)
1961 International...
2021 New Holland C327 Compact Track Loader (A57024)
2021 New Holland...
UNUSED FUTURE XGJ 40" MINI HYD ROTARY TILLER (A52706)
UNUSED FUTURE XGJ...
