/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #281
That's smart. I have pallet forks and already converted my factory bucket when I added the SSQA front assembly. The $2000+ for a lightweight grapple is a hard pill to swallow. I may have to take a hard look at that thumb.
Yes, the cost for an EA is high. I would like one but it’s hard to overlook MTL for half that...but the weight is 120# more than EAs.....as we know with these machines weight is essential. That and the portability of the thumb won me over.
I have the older DL95. Same thing, I just ordered through my dealer who obviously knows I have a GC1710/DL95 and the kit was all sized to install out of the box. I also used a 4pin trailer plug and cut 2 of the 4 wires off flush to be able to remove my FEL. I'll probably switch the plug to a 2 lead weatherproof plug down the line as I get my machine dirty and power wash it... Water is the enemy of electronics so I want something more resistant to the moisture
Yes, I assume when they get the FEL dimensions for a specific model tractor/model FEL, it's design ready for additional customers with the same tractor/FEL.
And I also use a flat 4 wire trailer plug for installing/removal of my MF snowblower for keeping the electric chute/deflector switches always mounted in the cab.
When I remove the snowblower, I have an additional 4 wire trailer plug with the wires cut and taped next to the plug that I plug into the one in the cab to keep the 4 pins clean during the summer.
KC
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #283
Little bit of driveway rehab and a shed pad for a customer.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #284
Tomorrow will be a good day!
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #285
You bet! A thumb for the BH is definitely one of the best additions you can have, IMO. Amazing what you will now be able to lift & move.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #286
Please share pictures on the thumb when installed and let us know how it goes.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #287
Test fit, with dinky little bolts.
Off the the dealer for hoses and real bolts!
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #288
What size grapple did you end up ordering?
I'm following this extremely closely as I am strongly considering adding this and 2 mounts to my loader and pallet forks.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #289
I wanna see that thing mounted on the forks.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #290
All plumbed, bolted down and functioning!
It’s a 24”
The forks and debris forks will be a while, have to buy the bases and have some welding done for the plate, to mount the bases to.
2004 Freightliner FL60 Ambulance (A56858)
2004 Freightliner...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
KBH 25T Tender (A56438)
KBH 25T Tender...
David White Meridan LT6-900 Level Transit, S/N D94224 (A59076)
David White...
3ft Chevrolet Tailgate Sign (A57454)
3ft Chevrolet...
