/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #761
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #762
Yes, KC! I haven't needed to use my blower since I put that together with the 1/4" UHMWPE strip, so I just went out to ensure there ISN"T a conflict -- Whew! Nope, the auger clears by just about 1/4". I hadn't even looked at that before so I'm glad you mentioned it! I can see where a 1/2" piece of PE there would not work.
If & when we ever get any more snow where I need to use it, I'll let you know how it works. My biggest concern now is that I only have about 1/4" of the plastic sticking out; not sure how long that will last before I have to flip it. After I use up my 3 pieces of 3" wide PE I'll look at getting something wider.
In the meantime, I did order a 1/2" thick piece -- maybe that will be stiff enough to not flex upward without the use of the OEM blade on top of it?
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #763
odd worked for me even logged out and different browser. of well internet is all magic anyway its a wonder it works.
was link to these
want to make sure on sizing as I have not done any measuring yet.
The SpeeCo S070904ZBU Lynch Pin can be used for numerous farm and other applications. The pin is zinc plated for long-term performance. Each pack includes two lynch pins. The overall length of the pin is 2-1/8 in., while the usable length is 1-1/4 in.
Diameter of pin: 1/4 in.
Usable length: 1-1/4 in.
Shank length: 1-3/4 in.
Overall length of pin: 2-1/8 in.
Clevis lynch pins are zinc plated for long-lasting use
Pack includes two lynch pins
Dmacleo, I bought the smallest ones they had on the shelf, 3/16" pin diameter. Terminology gets confusing, they're called lynch pins, the ones they replace are called hair pins, and both go into...pins (the ones holding the loader support legs up)??? Anyways, I needed to enlarge the holes in the "leg" pins for the 3/16" lynch pins.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #764
ok set ordered had 3/16 so thats good to go.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #765
Broke the fender! More beauty marks, lol
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #766
What happened MoMower?
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #767
Clearing trails, I think something got caught in the chains and came up against it. Took a chunk out at the bottom where it meets the floor board and just in front of the gas tank.
I’ll get a price for one, but I’ll probably just patch it.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #768
I値l get a price for one, but I値l probably just patch it.
I'm partial to doing this:
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #769
If I had the pieces I would glue and then zip tie, and so it goes.....
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #770
2015 Wanco Towable Solar Message Board (A56857)
2015 Wanco Towable...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A59575)
2018 INTERNATIONAL...
PALLET OF METAL AMMO BOXES (A58376)
PALLET OF METAL...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
500 BBL FRAC TANK (A58216)
500 BBL FRAC TANK...
Tool King 12-Ton Hydraulic Pipe Bender (A59076)
Tool King 12-Ton...
