What Implement would you use to clean up these ruts?
   / What Implement would you use to clean up these ruts? #21
On my property I've dealt with tractor-swallowing ruts from log skidders: OK, tractor didn't disappear, but I once high-centered (with the B7800- ALWAYS cross at an angle, never perpendicular!). Used a box blade with rippers (same B7800); took lots of time but it was worth it.
I'd like to think that discing would work for me, but I don't have a disc and am not sure it's worth getting one to test out with.
A rototiller might also be something to use. I've got one, so it's an option for me: have not attempted to use it for such as it's a fairly recent acquisition.
Also, a tooth bar on the bucket might be helpful for initial passes (if back-dragging).
Spring tooth?
   / What Implement would you use to clean up these ruts? #22
Found a picture of some of the ruts that I've had to deal with (took me several hours but I managed with my B7800 and a 5' boxblade):
What it looks like now (about 8 years later, with lots of other work done):
   / What Implement would you use to clean up these ruts? #23
We had massive ruts from when they dropped of trusses. Tiller make short work of them. I needed a tiller for another project so it made sense to buy one.
If you can find one now used buy it. Sell it in the spring when you are done w your project and they are in demand.
   / What Implement would you use to clean up these ruts? #24
I’d use a box blade with scarifiers to level those ruts and finish grade everything with a landscape rake if it were me.
   / What Implement would you use to clean up these ruts? #25
I would likely use my rake to even things out and then back drag with the bucket.
+1. They key is to wait until the ground dries out enough to support the tractor without sinking in but is still workable enough for the implements. I have done a lot of this type of rutting. You may find a good rake is all you need. You most likely will have to make a final pass with a rake when the ground has thoroughly dried for the final smoothing.
This is my 7' rake that works well for everything I have tried, including light box blade type work. With wheels, it weighs 450 - 500 pounds. Wheels are a great help, even with T-N-T.
Everything Attachments Landscape Rake, Root Rake
   / What Implement would you use to clean up these ruts? #26
I would use a landscape blade on the whole yard. Smooth it and plant it. That way you have uniformity.
MCELROY COOL PACK 20 (A50854)
MCELROY COOL PACK...
2015 MACK GU713 WINCH TRUCK (INOPERABLE) (A50854)
2015 MACK GU713...
Willmar 4300 Wrangler Loader (A51039)
Willmar 4300...
2017 JLG Skytrak 6036 6,000LB 4x4 Rough Terrain Telehandler (A50322)
2017 JLG Skytrak...
2000 MACK RD688 TRI AXLE DUMP  TRUCK (A51222)
2000 MACK RD688...
2016 PETERBILT 579 TANDEM AXLE SLEEPER (A51219)
2016 PETERBILT 579...
