What is Cat 1 and cat 2?
   / What is Cat 1 and cat 2? #2
The 3-point hitch comes in 5 different sizes, numbered from 0 to 4. The differences between them are the dimensions of the triangle and the size of the three connecting pins.
The lower lift arms on a 3ph cat 1 are 26" wide, with the top link being 18 inches above the center line, between the two lower lift arms. The lower lift pins are 7/8" in diameter, and the top link pin is 3/4". The cat 1 hitch is used on tractors from 20-45 hp.
A cat 2 hitch is 32" wide. The top link is located 24" above the center line between the two lower lift pins. The lower lift pins are 1-1/8" inch in diameter. The top link pin is 1" in diameter. The larger Cat 2 hitch is designed for use with tractors ranging from 40-100 hp.
   / What is Cat 1 and cat 2? #4
By definition, my Ford 1100 13HP tractor should be Cat 0, but its Cat 1. So if you're looking at a specific tractor, you might need to check the specs to see what category the 3P is. I'm limited to the smaller Cat 1 implements, but can run those just fine, and I think there's a bigger selection of Cat 1 vs Cat 0.
   / What is Cat 1 and cat 2? #6
Welcome to TractorByNet!
I moved your thread to the Attachments forum. :)
   / What is Cat 1 and cat 2? #7
   / What is Cat 1 and cat 2? #9
Ha ha even Briana does a double post.
   / What is Cat 1 and cat 2? #10
Thanks jeff9366.
That TractorData table is a lot of help :cool2:
Unused 2024 AGT H15 Mini Excavator (A59228)
Unused 2024 AGT...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
WOODS 3120 BATWING MOWER (A60430)
WOODS 3120 BATWING...
2006 Ford F-750 Fuel and Lube Truck (A59230)
2006 Ford F-750...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2022 Kubota LX2610SUHSD Compact Utility Tractor (A55315)
2022 Kubota...
