What is Cat 1 and cat 2?
   / What is Cat 1 and cat 2? #2
The 3-point hitch comes in 5 different sizes, numbered from 0 to 4. The differences between them are the dimensions of the triangle and the size of the three connecting pins.
The lower lift arms on a 3ph cat 1 are 26" wide, with the top link being 18 inches above the center line, between the two lower lift arms. The lower lift pins are 7/8" in diameter, and the top link pin is 3/4". The cat 1 hitch is used on tractors from 20-45 hp.
A cat 2 hitch is 32" wide. The top link is located 24" above the center line between the two lower lift pins. The lower lift pins are 1-1/8" inch in diameter. The top link pin is 1" in diameter. The larger Cat 2 hitch is designed for use with tractors ranging from 40-100 hp.
   / What is Cat 1 and cat 2? #4
By definition, my Ford 1100 13HP tractor should be Cat 0, but its Cat 1. So if you're looking at a specific tractor, you might need to check the specs to see what category the 3P is. I'm limited to the smaller Cat 1 implements, but can run those just fine, and I think there's a bigger selection of Cat 1 vs Cat 0.
   / What is Cat 1 and cat 2? #6
Welcome to TractorByNet!
I moved your thread to the Attachments forum. :)
   / What is Cat 1 and cat 2? #7
   / What is Cat 1 and cat 2? #9
Ha ha even Briana does a double post.
   / What is Cat 1 and cat 2? #10
Thanks jeff9366.
That TractorData table is a lot of help :cool2:
2005 Isuzu NQR 4 door box truck with folding gate (A56438)
2005 Isuzu NQR 4...
2019 CHEVROLET SILVERADO 11FT FLATBED (A59905)
2019 CHEVROLET...
1762 (A58375)
1762 (A58375)
Landoll Lowboy Trailer (A56438)
Landoll Lowboy...
1611 (A57192)
1611 (A57192)
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
