What is "dirty electric"?
   / What is "dirty electric"? #41
K7LN said:
It's purpose built and, as such, does it's job. I wouldn't be surprised to find the frequency off too. But do the lights care? :)
Incandescent lights don't care. They will burn out faster if you overload them. That's about it.
   / What is "dirty electric"? #42
If the frequency holds, sounds like the engine governor is good. As for the voltage variation, a descent generator, like Leroy Somer should have a voltage regulator. Cheaper generators use a scheme where the voltage is speed dependent and set for 60 Hz, but better gens use a separate electronic voltage regulator. Check it out, and it may be a bad regulator. My Mecce Alte head holds voltage within a volt or two.
paul
Well after reading the information on this post. I went down to my shop and did some more checking on my gen. I might be in for some serious expense or retrofitting. I just purchased one of these little light plants that you see construction workers use at night along the highway. It is a 6000watt continous run, with a Leroy Soner gen head and a Kubota 850 engine. I went and did a voltage check again yesterday and found I am getting 130 volts. About 125 with a 100watt bulb and when plugging 2 1500 box heaters it drops to about 105. The engine does not pick up any speed. I am wondering if they even put a governor on this type of engine, since it is set up to run lights only and set the speed and forget it because nothing else is kicking on like at a house. I ordered one of those frequency meter off e-bay which should be here by the week end. I am going to try and stop by and ask a Kubota dealer and see what he says, and if I get time I am going to stop by a Sun Belt rental place as they have several light plants and see how they are set up. I am beginning to get a bad feeling.
Well I stopped by a Kubota dealer and they said there is no provision for adding a governor to this engine for a gen. Stopped by Sun Belt, which rents out light plants and they said that light plants have no governot, just a throttle setting and are not designed to have loads applied at random like a home gen. Sounds like I am going to be looking for a different gen. Trying to find out if aftermarket makes a electronic speed sensor that would work.
   / What is "dirty electric"? #44
You could put a Sola ferroresonant transformer between the light plant genny and your load to act as a regulator. But they are not cheap especially at higher currents.
http://www.bonavolta.ch/hobby/files/sola.pdf
James K0UA
   / What is "dirty electric"? #45
Don't be misled, all diesel engines have governors built in the injection pumps. Diesel's don't use just a throttle control. The major difference is that engines that are supplied specifically for generators may have a governor that has tighter control. But every Kubota engine will have a governor. The basic engine, such as on a tractor, will track within a few hertz. I think you will find that the frequency does not deviate much on the gen setup you have. It still sounds to me like a voltage regulator issue.
paul
   / What is "dirty electric"? #46
There are non critical loads like electric heaters and light bulbs (probably others to) that don't require good frequency and voltage regulation. Having a frequency and volt meter (kil o watt for example) will help you deal with this. As said there may be a regulator problem. A fan should work ok too.
Well I got my frequency and voltage meter today. I am sure having truouble tracking down any one that knows any thing about a Leroy Somer Gen. It was sold by Coleman enginerring but the only thing Coleman had to do with it is put their sticker on it. Cant get much info from Leroy Somer. When I hook up my meter and speed the engine up to where it reads 60 hrtz it is reading 89 volts. When I speed it to where it reads 120 volts then I am getting 73 hrts. When I apply 2 1500 watt heaters and set the engine speed to where I am getting 60hrts, I get 82 volts. When I speed it up to where I get 120 volts then I get 79hrtz, unplug the heaters and if I dont change the engine speed it reads 150 volts, 79hrtz. This I took the covers off the gen. and there is no regulator for this gen. and according to one person I talked to they said one could not be added to this type of set up. On person on here said it might be a bad capacitor. It appears to have a new capacitor, but it was mounted so that viberation wore off the specs. It is a Dayton (Granger) brand and Coleman said it should be 70 MFD 440 volts. I can see the 440 volts but not sure about the MFD. I looked in Grangers book and they do not list a 70mfd. Only a 60 and a 80. I took it to a elec shop and they couldnt tell me if it was good or not because they didnt know what size it was. It does have two diodes in the system but the genset will have to be pulled to get to it to unsolder the connections. Some one asked me if I knew if they were good? Any one got any ideas. Do I need to install a larger capacitor or smaller one. Dont want to guess wrong as they are not cheap. Do you think one of the diodes is bad? I need to get the voltage up and the hertz down. If you think I should start a different post to get help, please let me know. As far as the governor question, they do have a built in governor to limit top speed but no provision for installing one that will react quickely to generator loads. One co. said they could supply me with a engine speed control system ($1000.) and I would have to drill holes in the flywheel and mount a sensor. Dont want to go that route. I even thought about a aftermarket cruse control system I use to install on cars in the 70's. There was no speedo conection made to the cable at all, only a magnet and a sensor taped to the drive shaft, a vaccum servo hoked to the throttle, a hose to vaccum source and battery connections and cruse button on steering wheel. I have no idea where I could find one now.
   / What is "dirty electric"? #48
Give it a coat of wax and put it in the next local consignment auction. Time to cut bait and buy something that will fill your needs reliably.
You are trying to make cookies out of cat dung.
   / What is "dirty electric"? #49
Well said. This generator was not designed to run anything but lights. Even with a regulator this will not put out the right frequency and voltage at the same time. You risk damaging most things that you plug into it.
   / What is "dirty electric"? #50
:thumbsup::thumbsup::thumbsup:
What they said.
2018 JLG G5-18A (A50123)
2018 JLG G5-18A...
UNUSED X-STAR 101" X 20' LOADING RAMP (A51247)
UNUSED X-STAR 101"...
2022 John Deere R4023 Self-Propelled Sprayer (A53485)
2022 John Deere...
2015 Freightliner Bucket Truck (A52748)
2015 Freightliner...
2024 JOHN DEERE 1025R LOT NUMBER 106 (A53084)
2024 JOHN DEERE...
2020 Bobcat T595 Compact Track Loader Skid Steer (A55851)
2020 Bobcat T595...
