BXpanded
Silver Member, Approved Advertiser
I own a BX 2350 so my comments might or might not be revelant. I suspect the setup is similar.
First off, mine is the kind that is supposed to stop suddenly and it does but I also had problems with it creeping forward.
This problem is worse when cold. It also worse when just partly pushing the Hst pedal down. If the pedal is floored and let go of suddenly, it stops quickly. It's worse in high range because you are less likely to have the pedal floored, as you feather it mine will often still creep forward.
I've spent quite a bit of time studying the linkage and think the main large return spring isn't stretched very much at light pedal applications, hence poor return.
I disconnected the dampener on mine and that helped, but it's still a problem.
Greasing the linkage doesn't seem to help. I disconnected the linkage from the pedal and it pivots freely, grease or no grease.
I think cutting part of a coil out of the main return spring would cure it. It might also cause problems, such as aggravating the sudden stop, increased pedal effort, and probably other things I've haven't thought about.
Is having the tractor creep forward a safety issue? It seems so to me.
The manual for the BX24 which is a 50 series machine, (50 series includes BX24, and BX2350) calls out the adjustment of the neutral spring as a 100 hour "Service Intervals" maintenance item in the "Maintenance of the Tractor" section. The same maintenance requirement is shown in the manual for the 70 Series BX25D (the 70 series includes the BX25D and BX25D-1, BX2370 et al.) .
I have performed this adjustment on the 50 Series and it is quite easy.
The 60 series(BX25, BX2360,..) implemented the dual action damper that is apparently still used today in the 70 series. Although I don't have a 60 series manual, I would guess that the warnings are the same as those in the earlier and later series. (Citation needed from a 60 series owner)
There is a diagram in each manual that shows the HST Neutral adjusting nut. The diagrams are different for the 50 series than for the 70 series due to the change in the damper but are very similar.
Both of these manuals state, "WARNING To avoid personal injury: Do not operate if tractor moves on level ground with foot off speed control pedal. If tractor moves on level ground with foot off the pedal, or, is too slow in returning to "NEUTRAL" position when removing the foot from the pedal, consult your local KUBOTA dealer."
Whether it's a 50, 60 or 70 series machine, If it "ain't stopping" on flat ground, it is out of adjustment or some part is malfunctioning.
WARNING is the 2nd highest ranking, 2nd most serious, notice flag used in the KUBOTA manual so it is not to be ignored. If your dealer can't fix it, contact Kubota. I'm pretty sure they'll find someone who can
