What is the best radiator flush and coolant??
   / What is the best radiator flush and coolant?? #1
belah
Bronze Member
South Central Louisiana
Kubota M4030SU 1992
I have a 1992 Kubota M4030SU and the temp guage runs between normal and hot during heavy operation (it used to stay on normal all the time). I'm wondering if I need to flush the radiator or just change the coolant? It's been a long time since the coolant was changed and the radiator has never been flushed. What is the best radiator flush and coolant that you have used in the past? What would you use in your tractor? Also, do I need to mix the coolant 50/50 with water? Thanks in advance!!:confused:
   / What is the best radiator flush and coolant?? #2
Most any brand name flush will do. I would use a diesel rated coolant at 50/50 mixed with distilled water. Also take a good look at the air side of the radiator, a clogged radiator will also overheat. A hard working engine on a hot day should run at higher temperatures.
   / What is the best radiator flush and coolant?? #3
1+ on the check the radiator for blockage .If you have an air compressor try blowing from the back side of the radiator,or when the engine is cold water flush from the back side.
   / What is the best radiator flush and coolant?? #4
Careful with the pressure or you will bend the fins and block the radiator.
   / What is the best radiator flush and coolant?? #5
Another fan here for checking the radiator for being clogged up with dirt and debris on the fins externally. Take off the cap and look down inside to see if the tubes look clogged up. Another thing to check is belt tension to make sure the belt driving the water pump isn't worn and glazed up. Last thing is if the impellors on the water pump are worn you won't flow as much water..My two cents worth of wisdom..
   / What is the best radiator flush and coolant?? #6
I clean and rinse with automotive flush--Super Flush?---from Walmart and rinse a couple times with distilled water.
For anti-frreze I use pre-mixed Deere anti-freeze because it's made with de-ionized water and because
they make only one grade for all their equipment--and some of it is very expensive.
In my youth I mixed it and did all sorts of stuff but with 5 year coolant the difference in price is minimal.
Just my two cents.
   / What is the best radiator flush and coolant?? #7
Flush with calgonite and distilled water.
   / What is the best radiator flush and coolant?? #8
make sure the outside is clean first. i use a high pressure washer on all my tractors,you have to be careful .its hard to get them clean.
   / What is the best radiator flush and coolant?? #9
It's particularly important for a diesel to have a well functioning cooling system & for it to have an equalling well functioning oiling cooling system i.e. the engine oil plays an important part in heat transfer. Anyway, the good news is that to fix the cooling system is one of the easier jobs you can do on a diesel engine. Your machine is 20 years old - you don't say how many hours you've put on her?? If you have basic bench experience and a few tools you could fit a new water pump, change the engine to radiator hoses, fit a new thermostat and have the radiator reconditioned. Your Kubota would have one of the older and very well made radiators. Typically, a radiator shop will remove the top and perform a thorough clean out of the radiator. So, for around the sub $400 mark you can completely revamp your system (all parts with your own labour). I'm just doing exactly this on my Ford 4110 at the moment and have done it on other engines in the past. The point I'm making is that it's no good just flushing the radiator if the rest of the system is looking tired. It's worth borrowing a torque wrench to tighten any bolts and make sure you tidy up the threads as well. Best, Ged
   / What is the best radiator flush and coolant?? #10
Zetor 5043 putting out some water but not heating up would wash out help any ideas or could it be gasket new to this as I am not high tech good luck to all
   / What is the best radiator flush and coolant?? #11
I use Peak Super Cleaner Flush. Run for six hours then drain and flush with distilled water, run for 15 minutes then drain and add AF.
I clean the machine with a leaf blower after working in the summer.
One thing I did notice was the temp was rising before the flush and dropped back a bit but not back to normal. I found the thermostat was warped and not seating properly preventing the radiator from having enough time to cool it. Replaced the thermo and problem solved.
   / What is the best radiator flush and coolant?? #12
I did a thorough cleaning of my old Farmall radiator earlier this year.
First round was vinegar.
Then Muriatic acid
Then a Gunk brand radiator flush
Then Washing soda.
It was amazing what came out of that thing.
   / What is the best radiator flush and coolant?? #13
Hi all zetor 5043 putting out some water from top of rad but not heating up had head gaskets done about 1 yr ago any advice will I wash out rad Or could it be gaskets again .? Any comment welcome new to this as I am not high tech Paddy c
   / What is the best radiator flush and coolant?? #14
Then Muriatic acid
Then Washing soda.
Have not seen this type of flush before. How did you dilute these products
to flush the cooling system?
   / What is the best radiator flush and coolant?? #15
Does not sound good for the water pump.
Preliminary Listing / Full Catalog Coming Soon! (A57148)
Preliminary...
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A55745)
2018 PJ TRAILER...
2020 Deere 750K LGP (A53317)
2020 Deere 750K...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2013 Chevrolet Van (A55973)
2013 Chevrolet Van...
1762 (A58375)
1762 (A58375)
