What is the best radiator flush and coolant??
   / What is the best radiator flush and coolant?? #11
I use Peak Super Cleaner Flush. Run for six hours then drain and flush with distilled water, run for 15 minutes then drain and add AF.
I clean the machine with a leaf blower after working in the summer.
One thing I did notice was the temp was rising before the flush and dropped back a bit but not back to normal. I found the thermostat was warped and not seating properly preventing the radiator from having enough time to cool it. Replaced the thermo and problem solved.
   / What is the best radiator flush and coolant?? #12
I did a thorough cleaning of my old Farmall radiator earlier this year.
First round was vinegar.
Then Muriatic acid
Then a Gunk brand radiator flush
Then Washing soda.
It was amazing what came out of that thing.
   / What is the best radiator flush and coolant?? #13
Hi all zetor 5043 putting out some water from top of rad but not heating up had head gaskets done about 1 yr ago any advice will I wash out rad Or could it be gaskets again .? Any comment welcome new to this as I am not high tech Paddy c
   / What is the best radiator flush and coolant?? #14
Then Muriatic acid
Then Washing soda.
Have not seen this type of flush before. How did you dilute these products
to flush the cooling system?
   / What is the best radiator flush and coolant?? #15
Does not sound good for the water pump.
Trailer Hitch w/ 2 5/16 Ball (A56469)
Trailer Hitch w/ 2...
2022 McConnel TRAXX RC28 43in. Remote Controlled Slope Mower (A55853)
2022 McConnel...
2017 Ford F-150 Crew Cab Pickup Truck with Liftgate (A55852)
2017 Ford F-150...
UNUSED FUTURE DIE-CAST TOY (A57192)
UNUSED FUTURE...
UNUSED SET OF FUTURE 13', 200AMP JUMPER CABLES (A57192)
UNUSED SET OF...
LIMA MAC 60KW GENERATOR (A58214)
LIMA MAC 60KW...
