What is the best radiator flush and coolant??
   / What is the best radiator flush and coolant?? #11
I use Peak Super Cleaner Flush. Run for six hours then drain and flush with distilled water, run for 15 minutes then drain and add AF.
I clean the machine with a leaf blower after working in the summer.
One thing I did notice was the temp was rising before the flush and dropped back a bit but not back to normal. I found the thermostat was warped and not seating properly preventing the radiator from having enough time to cool it. Replaced the thermo and problem solved.
   / What is the best radiator flush and coolant?? #12
I did a thorough cleaning of my old Farmall radiator earlier this year.
First round was vinegar.
Then Muriatic acid
Then a Gunk brand radiator flush
Then Washing soda.
It was amazing what came out of that thing.
   / What is the best radiator flush and coolant?? #13
Hi all zetor 5043 putting out some water from top of rad but not heating up had head gaskets done about 1 yr ago any advice will I wash out rad Or could it be gaskets again .? Any comment welcome new to this as I am not high tech Paddy c
   / What is the best radiator flush and coolant?? #14
Then Muriatic acid
Then Washing soda.
Have not seen this type of flush before. How did you dilute these products
to flush the cooling system?
   / What is the best radiator flush and coolant?? #15
Does not sound good for the water pump.
TEST YOUR BID BUTTON! (A57193)
TEST YOUR BID...
2019 FREIGHTLINER M2106 26' BOX TRUCK (A57192)
2019 FREIGHTLINER...
UNUSED FUTURE D3T 32" EXCAVATOR HYD TILT BUCKET (A57193)
UNUSED FUTURE D3T...
UNUSED WOLVERINE PD-12-08D HYD POST DRIVER (A57193)
UNUSED WOLVERINE...
2019 Chevrolet Tahoe SUV (A55853)
2019 Chevrolet...
UNUSED SDLANCH SDLC2030FT20'X30' ALL STEEL CARPORT (A57193)
UNUSED SDLANCH...
