What kind of glue?
   / What kind of glue? #21
one would think the metal plate being glued to the top of the cannopy would block (most) of the uv ;)
   / What kind of glue? #22
I've used quite a bit of 3M 5200. I hate the stuff. It is almost impossible to get off after the mistake. :D
Then again, it may be just what you are looking for.
   / What kind of glue? #23
I second this. 5200 is great if you never, ever plan on changing anything. If you think it may have to come off at some point, then use 4200, which is similar in qualities but can be separated at a future date without shredding both parts.
Sent from my SCH-I500 using TractorByNet
   / What kind of glue? #24
3M 5200 is a marine adhesive
As a shipwright/fabricator I have used it many many times and IMO it is overkill to the extreme for this application...
5200 is expensive to begin with and it requires it's own removal agent that is equally expensive...
JMO...
   / What kind of glue? #25
I would use plain old contact cement / 3M Weatherstripping, around here we call it "gorilla snot" . Spread on your canopy and beacon, let dry until not sticky, and set the beacon in place.
   / What kind of glue? #27
Is the magnet strong enough to hold the metal through the plastic? No glue required. Hold the plate on the underside of the canopy and put the light on the top.
John even if it is powerfull enough I do not want that
sudden "Surprise" even if it didn't hurt. It could be cause
for a momentary distraction then the sky will fall kinda deal...
I appreciate ALL the comments. 5200 is in my aim...
   / What kind of glue? #29
The 3M 5200 suggested above is a very tough and permanent solution, should work very well for your uses. The 3M 4200 is similar but easier to remove although both will bond and hold the beacon with out any problems. I use both for boat repairs but the 5200 has to be ground off to remove, that stuff is tough.
I have a tube of 4200 here and the product code is 06560 should be available at marine supply stores.
   / What kind of glue? #30
For this type of problem I resort to one of my favorites.
A quality caulking that is polyurethane based and similar to the adhesive used to install windshields.
The caulking brand is FLEXTRA, comes in some 20 colors and sticks to just about any clean surface. Never gets hard and brittle and is even paintable.
Because it remains flexible it is perfect for dissimilar products that will have different expansion rates with temperature changes.
OH, and it sells for (generally) less than $5.00 a tube.
   / What kind of glue? #31
napa has that urethane stuff for 7$ HERE IN MY AREA.. AND YEAH.. GOOD GLUE.. GOOD SEALANT TOO.
   / What kind of glue? #32
Piloon -- that brand of caulking comes from Quebec -- made by Mulco -- part of Sico coatings -- not sure you would see that in the US
   / What kind of glue? #33
you can get an equivalent though.. urethane window ahesive..e tc. possibly a 3m brand product. I may have some at ope if someone needs the number.....e tc..
   / What kind of glue? #34
3M VHB is great. You can get it in different strengths and tape thicknesses. You will find many many uses for it on other projects and repairs.
   / What kind of glue? #35
RTV silicone.
you know.. if'n it was me.. I'd squirt a half tube or clear rtv on it and stick it down.
it'l sure stay.. AND be removeable if ever needed.
best of both worlds
I agree. I used silicone calk to put a 4" square piece of metal in the roof of our BX cab and I put a mag mount light on there for the winter.
I hit both sides with a alcohol wipe before putting down the calk and so far, so good. It has been there for a couple of years now.
Aaron Z
   / What kind of glue? #37
industrial adhesives can be impressive. i saw a special on disc channel.. they glued 2 pieces of sheet metal togetehr.. then tried to pull them apart. the metal yeilded before the bond broke.. :)
2022 FORD F-250 STX CREW CAB TRUCK (A59823)
2022 FORD F-250...
2016 John Deere 4044R 42HP 4WD Utility Tractor (A59228)
2016 John Deere...
2019 TAKEUCHI TL8 SKID STEER (A60429)
2019 TAKEUCHI TL8...
2003 PETERBUILT PB330 DUMP TRUCK (A60430)
2003 PETERBUILT...
Caterpillar 928G Articulated Wheel Loader (A59228)
Caterpillar 928G...
1996 International Water Truck with a Caterpillar Engine (A61306)
1996 International...
