What kind of glue?
   / What kind of glue? #11
I use a lot of double sided carpet tape. The cloth tape is VERY strong.
   / What kind of glue? #13
Thanx so much for the inputs.
Rivets will make a water breech, I thought of a piece of metal under
as well but my receiver is in the way and I need a more pernament
mount. Some of the suggestions look like winners for sure and I will
be looking into them.
Thank YOU!
You could dip the rivets into goo glue or some other type of water proofer like RTV or?????????????
   / What kind of glue? #14
<snip>
I am looking for suggestions for a proper, long lasting glue...
It is for a place to set my magnetic amber beacon. I do not
want it solid, if I hit a limb I want to it fall and hang from
the wire before it breaks.
TIA!
For a GLUE use a foaming Gorilla Glue, that might allow it to release prior to breaking.
But I'd recommend a strong "hook and loop" material. This would give a better chance of "hang from
the wire before it breaks".
   / What kind of glue? #15
   / What kind of glue? #16
you know.. if'n it was me.. I'd squirt a half tube or clear rtv on it and stick it down.
it'l sure stay.. AND be removeable if ever needed.
best of both worlds
   / What kind of glue? #17
best of both worlds
This is a good suggestion....but almost regardless (other than the urethane based adhesives, like those that foam up and are hard to remove) preparation of both surfaces for the selected adhesive is paramount for its effectiveness...
Silicone based adhesives are very unforgiving when it comes to applying to smooth(er) surfaces...
   / What kind of glue? #18
i silicone 'temp' stuff to GLASS all the time... works great.
start with 2 clean surfaces.. glue and hold in position with a jig till cure.
lotsa products made for bathrooms to glue stuff to tile or faux marble is rtv.
   / What kind of glue? #19
There is a glue called Goop I have found to be very effective. For outside get the kind with a pigment in it . UV will break down the clear. Home Depot has it.
   / What kind of glue? #20
Try 3M VHB tape. Commonly know as "body side molding tape". Plus the benefit is if you do need to remove it just use a piece of fishing line or thin wire to cut through it.
3M VHB Tape
+1
Good enough to hold moldings on a car at 75mph.. good enough for a tractor !
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2022 CATERPILLAR 242D3 SKID STEER (A60429)
2022 CATERPILLAR...
2018 Deere 323E (A53317)
2018 Deere 323E...
Wagon Wheel Rocking Chairs (A55758)
Wagon Wheel...
2016 KOMATSU D65PX-18 CRAWLER DOZER (A60429)
2016 KOMATSU...
2020 CATERPILLAR 299D3 XE SKID STEER (A60429)
2020 CATERPILLAR...
