what on earth does electricity cost near you?
   / what on earth does electricity cost near you?
I moved a few miles south by the way so now I pay about $65 per month.... Very hard to belive compaired to $125 to 200 during non winter months. I will have to see what it cost this winter for electric but now I have natural gas heating.
   / what on earth does electricity cost near you? #172
I think our current rate is less than 4 cents per kilowatt right now. When we signed up it was 4.26. It used to be over 6 cents from our power company but voters voted to shop around for better rates through an "electric aggregation program". Some months we end up paying more for meter usage, customer fees and taxes than we do for the electricity. Our lowest bills are about $50 and highest during airconditioning season are usually less than $120. Low usage would be around 600 kwh and high about 2000 kwh. We're in about a 1000 sq. ft. manufactured house.
This is why I'm running a space heater right now after paying 4.69 per gal. for propane.
Kevin
4 cents per KWH for electricity and $4.69 a gallon for propane. Great deal on electricity, more than double what the propane should cost. I guess it all evens out.
   / what on earth does electricity cost near you? #173
I pay a progressive rate for electric. Starts out at 19 per KWH for the first 500 then it drops to about 12 for the next 500 and then goes to 9 for any additional. This is due to being located in an extremely rural area. Seems to also give an incentive to using more electricity.
I just bought 800 gallons of propane for $1.60 a gallon.
   / what on earth does electricity cost near you? #174
I'm not trying to drift, but rather posting this for 2 pieces of data cited.
Ammonia
First paragraph quotes a 1 billion dollar charge, in one month, above market value for electricity.
Fifth paragraph:
"Industry is circumventing power generation, delivery, debt and Global Adjustment charges by doubling self-generated diesel power from 5%-10%."
Food for thought. Also partly explains tighter diesel emission standards in certain areas.
Rgds, D.
   / what on earth does electricity cost near you? #175
Latest rates here under TOU:
Peak: 14.0 cents/kwh
Mid-peak: 11.4 c/kwh
Off-peak: 7.7 c/kwh
I should compare that Peak # (+ the 18 surcharges on the bill) against generator use - a Natgas fueled gen may actually be cheaper, and perhaps even gasoline too, these days.
Merry Christmas to all, esp. those that can't afford to run the lights !
Rgds, D.
   / what on earth does electricity cost near you? #176
Low power rates here, .0233 @ KWH. $8.80 month minimum charge. All electric home, except for my woodstove which I burn as supplemental heat all winter. Truth is the elect. rate is low enough that I don't need to burn the woodstove cept I enjoy the wood labor and peace of mind that if the power goes off, I can keep the house warm, the power rarely goes off in a storm here, and usually back on in an hour or two. Douglas County P.U.D. Wa. State. Columbia river hydro.
   / what on earth does electricity cost near you? #177
Wood is a nice a backup, but at those rates elec. heat is attractive.
I had an all-electic house years ago, and did appreciate the ease and accuracy of zone control with baseboard heat.
If I was running your local Chamber of Commerce, I'd have that elec. rate front page on their website.
Rgds, D.
   / what on earth does electricity cost near you? #178
The lastest nonsense here:
NEWSTALK 1010 - IN-DEPTH RADIO :: Widen difference between peak, off-peak electricity prices: Ontario watchdog :: News - Article
Edit - do not read the Comments below that article, if you mind seeing swear words.
They are starting to talk up a 4 or 5x differential in TOU rates, compared to the 1.8x now.
That way we freezing peasants are supposed to feel grateful, when they "only" jack it up to 3x the Off-Peak rate.
Rgds, D.
(P.S. - rasp21 - does Douglas County accept refugees from Canada ?)
   / what on earth does electricity cost near you? #179
Here in Central Florida .12 a kilowatt hour. Which is the reason I've changed out the air conditioner to a seir (18) with in house zoning, gone to a variable speed pool pump and a propane tankless water heater. Every time a bulb burns out I now install LED. The net result has been a reduction from over $500 dollars a month during the peak months to just less than $300 a month.
   / what on earth does electricity cost near you? #180
Here in Shawnee I pay $.01894 per kw. Low end is $.01879. Two taxes at $.00016 and $.00056 per kw.
Power company is pushing for higher rates. Our state commissioner rarely approves rate increases without just cause.
I converted my house to total electric to get away from the high natural gas rates for heating. Install ground loop GEO thermal heat and air.
Cost almost nothing for cooling and very little for heat.
GODWIN CD150 DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150 DRI...
2011 Kenworth T300 Jerr-Dan 21WSRB Rollback Truck (A52377)
2011 Kenworth T300...
40 CONTAINER (A52472)
2015 CATERPILLAR 323FL EXCAVATOR (A51246)
2015 CATERPILLAR...
2015 PETERBILT 367 (A52472)
2015 PETERBILT 367...
6ft Pull Type Hydraulic Dirt Pan (A51573)
6ft Pull Type...
