What shop tools can you not live without?
   / What shop tools can you not live without? #11
A sawsall was always a favorite, but come to like a 4 1/2" hand grinder with a 3/32" cut off wheel. Grinder does a lot nicer job then the sawsall whencutting up steel.:thumbsup:
   / What shop tools can you not live without? #12
whistlepig said:
A five pound hand sledge.
I've been expecting someone to say this one..
We all know the solution is always a bigger hammer...
   / What shop tools can you not live without? #13
It depends where I am. At my moms I use my craftsman drill a lot and a hammer is the tool of choice at my dads.
   / What shop tools can you not live without? #14
That is tough. My 6 1/2" Wilton shop vise, and my 4 1/2" grinder would be up there. My drill press is nice to have when I need it. Heck I used it as a lathe the other day when I needed to make some bushings. I chucked up some steel and used a file to take the OD to the right size (only had to change the diameter by .030"), and then used a hand drill and drill bit for the ID. My welder/generator and wire feeder is important too. I have been buying professional tools for 25 years and at times they are all important. There is no substitute for an air compressor when you need air, but moving to cordless tools has cut down on my need significantly.
I'd say my most important tool is my 25 years of experience as a mechanic.
Brian
As far as hammers, my favorite is my 13 pound rubber dead-blow. It comes in very handy when I'm putting Bobcat T300 tracks back on by myself.
   / What shop tools can you not live without? #15
I just realized that I could not live without
My MIG welder, grinder, 5lbs sledge, & table saw.
I really REALLY REALLY love my porta-band! That has become my go to saw to cut up all sorts of stuff! If you don't have one you won't know what you have been missing.
   / What shop tools can you not live without? #16
My dad loves the hammer...If it doesn't fit, the hammer will make it fit...:thumbsup: :laughing:
   / What shop tools can you not live without? #17
Tools or equipment? If we can lump them all together, I think I would have to rate an air compressor right up there at the number one position. Although a person can make-do without, a parts washer is just oh-so-nice to have. Its one of those things that you don't realize how nice they are until you've use one. My lathe and mill would be sorely missed too if I had to give them up.
   / What shop tools can you not live without? #18
EVERY tool in my shop would be hard to live without. It would mean farming out a lot more repairs. Like working on my cars, fixing things that break etc.
So heres a small list
Aside from the obvious hand tools (wrenches, pliers, screwdrivers, sockets, etc)
Air compressor and air tools
Vise
Welder
Torches
Floor jack/jack stands
Drill
Saws
Good fluke meter
And when it comes to woodworking (not the tedious kind) but framing/building/decks, etc
I absolutly could not live without my sliding compound miter saw. Once you use one, you will almost NEVER use a circular saw again unless you are ripping plywood or something. And mine was just a cheapie menards tool-shop brand 10" single bevel slider with stand for $139 on sale.
It has already built 3 pretty large decks (12x16, 12x20, and 10x20) blus countless other things like shelving and benches in the garage. I definatally got more than my money back out of it.
And when it comes to building/framing things, I could also probabally not live without my transit, 4' level, t-square, and a good tool pouch.
   / What shop tools can you not live without? #19
Besides wrenches, sockets, etc....
In no particular order:
Cordless Drill
Air Compressor
Drill Press
Metal Cutting bandsaw
MIG, TIG, Arc Welder
Vise
grinding wheel
shop Press
Skill Saw
Chop saw (compound Miter)
Saws-All
   / What shop tools can you not live without? #20
My 11-n-1 multi-tip Klein screw driver.
LOT: Tap & Die Set, Hole Saw Set, Snap Ring Plier Set (A59076)
LOT: Tap & Die...
2017 Freightliner MT55 Step Van (A56858)
2017 Freightliner...
2019 Ford F-550 Truck 4x4 Crew Cab Palfinger PSC6025 3 Ton Crane Service Truck (A55973)
2019 Ford F-550...
NEW Fork Extensions (A59000)
NEW Fork...
1094 (A58374)
1094 (A58374)
CAT 289D3 (A58214)
CAT 289D3 (A58214)
