Sorry workinallthetime, I have to respectfully disagree. Just because it is a diesel does not mean it has to be run at WOT all the time. That is a myth. The truth is that modern diesels ( ie: anything less than 50 years old) can be run at whatever speed is necessary to get the job done. Now, my dad's 1952 Caterpillar D4 dozer is designed to run at WOT, but WOT on that machine is 1300 rpms. Running at WOT will certainly not harm the engine and is the fastest way to get something done. However, getting the job done fast is not always the best way. Adjusting the engine rpms to the conditions is usually the most efficient. It just doesn't make sense to run the engine at WOT when doing a job that does not require maximum power. For mowing I agree that WOT is best even though it doesn't require a lot of power. It does require speed though, to get the needed tip speed on the blades. Bottom line is that today's diesels are variable speed engines and can be used that way with no ill effects.
