What should the settings be? Ranger 9
   / What should the settings be? Ranger 9 #1
Piston
Elite Member
New England
Kubota L4610 Hitachi UH083LC
Guys
I am borrowing a Lincoln electric ranger 9 to weld some 1/2" steel brackets onto my land pride box blade. What should the settings be and what type of rod should I use?
I don't know much about welding and nothing about the settings. I have welded before but people have always setup the welder for me.
I could really use your help :)
   / What should the settings be? Ranger 9 #2
I would set it on DC+, use 1/8-inch 7018, for flat welding I'd set the main selector at 160-max, and adjust the fine tune as needed. For vertical up I'd set the main selector at 120-max, and adjust the fine tune as needed. ;)
Thank you!
I'll give that a shot. :)
   / What should the settings be? Ranger 9 #4
Remember all those settings have the blue background, don't switch anything to a Mig setting / CV!
   / What should the settings be? Ranger 9 #5
Ditto, I have the same unit. Poor thing sits and collects dust waiting to save the day.
   / What should the settings be? Ranger 9 #6
i would use 1/8 6011 at about 100 amps.
   / What should the settings be? Ranger 9 #7
Out of curiosity Piston, do you have the manual for the welder? I would think Lincoln would have a cheat sheet of settings to use.
If you don't have the manual. I'll bet it's on Lincoln's website.
   / What should the settings be? Ranger 9 #8
Piston, that is a excellent machine you are using however, on 1/2 steel I would stay with 7018 but prior to welding I would spend time with your grinder for prep. on the job. I just finished a replacing a battery box on my 580D CK
Unfortunately I don't have a manual for the welder. I'll try out the settings mentioned and go from there. That's a good idea about looking on the website.
I'm excited to try it out on the box blade. I would have the other day but ran out of oxygen for the torches so I couldn't cut the steel. I just refilled so maybe I'll get to do some hurricane welding tomorrow :)
2013 COACHMEN CATALINA TRAVEL TRAILER (A55745)
2013 COACHMEN...
2004 Pierce Tilt Crew Cab Pumper Fire Truck (A59230)
2004 Pierce Tilt...
2003 Big Tex 10PI...
2018 MACK CHU613 (INOPERABLE) (A58214)
2018 MACK CHU613...
2020 DRAGON ESP...
2022 Wacker Neuson PDT2A 2in Portable Diaphragm Pump (A55851)
2022 Wacker Neuson...
