What size boxblade for 2516?
   / What size boxblade for 2516? #11
I have a 60" Atlas, its says heavy duty, but I think its weighs in a 400-500 lbs. You dont want to go any bigger, my 2816 does well but you know its back there, especially with the ripper teeth down. Some big roots will stop me in my tracks. Hope this helps.
   / What size boxblade for 2516? #12
Hello manganos,
I also have a Mahindra 2516 gear tractor, which I am enjoying very much. My dealer supplied a 60" Southern box blade with it, not for free, mind you <g>.
It came from Southern Farm Supply <http://www.southernfarmsupply.com>
They do sell at retail.
It is a durable no-frills product at a reasonable price and the tractor handles it very well. I worked my hard-packed gravel drive with it using the ripper bars and the tractor never flinched. The box has forward and reverse curved blades and all construction appears quite solid. The unit is marked standard duty which should be fine for non-commercial use.
   / What size boxblade for 2516? #13
I originally had gotten the 6 footer but the more I thought about the size I when back and got the 5 footer instead for the simple fact I didn't want to end up breaking parts as my needs couldn't justify that sizes and something that I could do in two passes instead of maybe one. For the price of the tractor I'd like to keep my problems down to a reasonable number and I didn't want to create any especially with my dealer 90 miles away. If it was a field tractor I won't have worried, but this is a compact and it's still easy to hook on to more than the tractor can handle even with the 5 footer now and 4WD. When your on retirement funds you have to start thinking about the little things.
   / What size boxblade for 2516? #14
You should be fine with the 5 footer but I don't understand your reasoning on not wanting to hurt the tractor by going to a 6 footer? A bigger implement will just hang up easier and cause your wheels to spin more often. Even a 5 footer is going to do that if you hook a big rock with the rippers down. Traction is like your shear pin. You should be more concerned about bending the implement. Nothing on your tractor should break besides traction but I've bent rippers that were 3/4 inch solid steel by hooking a rock and I have a med duty box blade. I wouldn't even consider a light duty one.
   / What size boxblade for 2516? #15
I plan on keeping my tractor a long time and if you can bend the rippers which are 3/4 inch steel then to me the tractor didn't break traction and the weakest item gave out which could have just as easy been an item in the drive train, larger device just equal more load that you can put on the tractor. Bottom line is it really worth it, bigger is not always better, I was taught to take care of your equipment. Also when you spin the tires you take the chance of cutting the tires on anything that not dirt and sometimes you have no ideal whats been buried at least on my land, done that already. Why take it to the dump when you can just bury it. Tires cost to much to replace and I'd much rather be safe than poorer.
Missed this posting from yesterday as he was using a boxblade: 4110 broken lower 3pt hitch
   / What size boxblade for 2516? #16
If you decide to go with the 5 footer you can do the same thing I did with my KK unit by going to Menard's in my case and getting a piece of steel plate 1/4 inch by 6 x 12 and then weld it at an angle to the boxblade with about ½ to 1 inch clearance from the bottom of the box. I've posted pictures of the modification before and to me it works great, I gain more size but by being at an angle less loading effect but when in reverse they help move more material and makes the boxblade a better tool, really great with snow.
All great info! I will try and get something this weekend :)
   / What size boxblade for 2516? #18
This has been mentioned before so you may already be aware of it but the one thing to watch out for are paper wasp that like to make nests in the square tube that holds the rippers, especially if you leave it sit outside as they'll find it.
John Deere 5045E for sale Auction
John Deere 5045E...
Volvo EC220EL (A60462)
2012 Husqvarna LTH18538 38" Riding Mower (A59231)
2012 Husqvarna...
2023 GREAT DANE FLP-0024-00053 53FT FLATBED TRAILER (A59905)
2023 GREAT DANE...
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
2016 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A60429)
2016 CATERPILLAR...
