What size FEL hooks
   / What size FEL hooks #11
   / What size FEL hooks #12
Well after stopping at a hardware store I got to see some grab hooks they had. I decided to go with the 5/16" hooks, a 3/8" link still slid into it.
I use the 5/16" hooks as well, 1/4", 5/16" and 3/8" chain all work with it.
   / What size FEL hooks #13
I used RV style slip hooks from TSC - about $10 each, I think. At the time I didn't have any welding equipment and drilling & bolting was a quick solution that has work well for the past 3 years. Like Easygo, I prefer to work with ropes most of the time. They weigh a lot less than chain and are much easier to work with - especially when you are dealing with lengths of 25 ft (or more). If there's a lot of dragging to be done, or abrasion is a concern, then I switch to 5/16" chain and use grab links on the slip hooks:
   / What size FEL hooks #14
Hey Guys,
I read through the other 1000 posts on FEL hooks and learned a lot. I am getting ready to put some hooks on my B2620. I am planning on having the 3x3 angle welded across the top of the bucket. I am thinking of having 1 slip hook on the top center and 1 slip hook on the back of bucket between the lift arms.
Now here is the question: I want 2 grab hooks on the top of the bucket, just outboard of the lift arms by 2" to 4" (1 hook on each side) I have a 5/16" chain but I was thinking of having 3/8" grab hooks welded on. Will the 3/8" grab hooks work ok with my 5/16" chain? The reason I am thinking of 3/8" hooks is I can the use the larger chain as well. I just don't have experience in using these hooks and don't know how much slop is in these hooks or is the groove pretty tight fitting. I am assuming a 3/8" chain would not fit in a 5/16" grab hook.
Thanks for the advise guys.
When I ordered my new Bucket I had them put two 5/16 grab hooks.
They work great.
DEUTZ MARATHON...
2022 RAM 2500 HEAVY DUTY (A55745)
2022 RAM 2500...
2007 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A58375)
2007 FORD F750 XLT...
JCB 2145 (A47477)
JCB 2145 (A47477)
Hydraulic rail grinder (A56436)
Hydraulic rail...
Forklift (A59228)
Forklift (A59228)
