What size of shear pin bolt??
   / What size of shear pin bolt?? #11
Depending on application, some shear pins are not bolts, or grade 2 bolts can be too strong. With my B7100, I think at least one was a big cotter pin, but I can't remember where it fit.
   / What size of shear pin bolt?? #12
Hard ( pun intended ) to get much softer than a soft bolt.. probably easier to just go down a size in fastener, or.. go to a specialty pin that is perhaps pre notched allowing it to shear easier.. or to a non steel softer fastener material.. like brass, aluminum, nylon.. etc
Soundguy
   / What size of shear pin bolt?? #13
1/2 inch sounds to big for a shear bolt. Like a previous poster said not all shear pins are bolts. I would try to find an oem pin to make sure.
   / What size of shear pin bolt?? #14
If it's a 1/2" hole it's got to take a half inch bolt or pin.. can't put something smaller in there and let it slop.. It will egg out the hole and shear on a shock load.
My 5' mower used a half inch bolt.. doesn't seem at all uncommon to me.
Soundguy
   / What size of shear pin bolt?? #15
a 1/2'' soft bolt will shear . that's what came standard in my cutter. I buy mine from H.D. I keep several on hand as I have broken these 1/2'' bolts several times.
Payment Instructions (A47477)
Payment...
2021 Allmand Bros Maxi-Lite II Light Tower (A52377)
2021 Allmand Bros...
Toro Mower (A50324)
Toro Mower (A50324)
2017 FREIGHTLINER TANDEM AXLE DUMP TRUCK (A54607)
2017 FREIGHTLINER...
2012 BMW 328i Sedan (A53424)
2012 BMW 328i...
2013 Ford F-250 Ext. Cab Pickup Truck (A51692)
2013 Ford F-250...
