What size of shear pin bolt??
   / What size of shear pin bolt?? #11
Depending on application, some shear pins are not bolts, or grade 2 bolts can be too strong. With my B7100, I think at least one was a big cotter pin, but I can't remember where it fit.
   / What size of shear pin bolt?? #12
Hard ( pun intended ) to get much softer than a soft bolt.. probably easier to just go down a size in fastener, or.. go to a specialty pin that is perhaps pre notched allowing it to shear easier.. or to a non steel softer fastener material.. like brass, aluminum, nylon.. etc
Soundguy
   / What size of shear pin bolt?? #13
1/2 inch sounds to big for a shear bolt. Like a previous poster said not all shear pins are bolts. I would try to find an oem pin to make sure.
   / What size of shear pin bolt?? #14
If it's a 1/2" hole it's got to take a half inch bolt or pin.. can't put something smaller in there and let it slop.. It will egg out the hole and shear on a shock load.
My 5' mower used a half inch bolt.. doesn't seem at all uncommon to me.
Soundguy
   / What size of shear pin bolt?? #15
a 1/2'' soft bolt will shear . that's what came standard in my cutter. I buy mine from H.D. I keep several on hand as I have broken these 1/2'' bolts several times.
72'' power rake (A53421)
72'' power rake...
2014 International DuraStar 4300 Street Sweeper Truck (A52377)
2014 International...
2011 New Holland Boomer 90 MFWD Utility Tractor (A53473)
2011 New Holland...
2005 FONTAINE 48 FOOT FLATBED (A53843)
2005 FONTAINE 48...
2018 JLG 1644 4x4 15,600lb High-Capacity Rough Terrain Telehandler (A52377)
2018 JLG 1644 4x4...
VERMEER NAVIGATOR 53 D23X30111 DRILL (A51406)
VERMEER NAVIGATOR...
