What size rotary cutter?
   / What size rotary cutter? #1
SMOKEEATERFF
Ford 4000
Well I am about to purchase a new rotary cutter and I am trying to decide what size. I had a 5 ft but it has kicked the bucket. Should I stay with a 5 ft or go up to a 6 ft? Right now I have a Ford 4000 tractor with front weight. May purchase a new tractor on a few years around the same hp. I am looking for a medium duty cutter, I have narrowed it down to Rhino, Land Pride and Woods.
   / What size rotary cutter? #2
A 4000 will handle a 6' just fine. I run a Bushhog 286 behind my NH TT45 (about 10hp smaller than yours) with only 4, 44lb weights on front and love it. The cutters you mentioned are all great mowers and I'm not trying to talk you out of them, but is there a reason your not looking at a BH?
I had looked at a bh286 online and they are comparable. I went to a dealer yesterday and he priced a squealer for $2k which is a lighter duty. He also said it was 7 ga deck I thought the 286 was 10 g so the squealer should be lighter duty.
   / What size rotary cutter? #4
You should be fine, you might want to be little cautious on hills.I know several guys who run the same set up as you described.Im partial to woods, md172 3pth, and john deere. just my 0.02 cts.
   / What size rotary cutter? #5
I think 286 has a 10ga top deck with 1/4" sides. SQ's are 10ga all over. There all good cutters, you can't go wrong with any of the brands you listed.
   / What size rotary cutter? #6
I run the 6' Bushhog SQ172 Squealer behind my Boomer 8N with 2 100 pound weights on the front without any problems. I cut 2" trees without difficulty backing up into the brush. The only time I break a shear pin is if I bottom out on mowing pasture.
   / What size rotary cutter? #7
I been using a SQ 600 for 12 yrs and have no complaints. Only thing I've ever done to it has been grease it and sharpen the blades.
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
2013 MAXX-D BUMPER PULL TRAILER (A58214)
2013 MAXX-D BUMPER...
1997 Ford Tandem Dump Truck (A59814)
1997 Ford Tandem...
excavator trenching bucket- one bucket per lot (A56436)
excavator...
2021 CATERPILLAR D3 LGP CRAWLER DOZER (A60429)
2021 CATERPILLAR...
19008 (A56859)
19008 (A56859)
