What size shear pin should I use?
   / What size shear pin should I use? #1
atcNick
Longview, Texas
Still shopping
I have a 30hp kioti tractor and a 5ft house brush hog. Broke my shear pin for the first time and I’m not sure what size pin I should replace it with.
   / What size shear pin should I use? #2
If I remember right:1/4"x4" grade #2 bolt.Do not use grade 5 or 8.
   / What size shear pin should I use? #4
TSC sells a 4 pack of shear bolts and nuts that’s pretty cheap if you shop there. Comes in a retail pack with heat shrink plastic over cardboard so you can peel one off and then hang the remainder on a pegboard or toss in a tool box and have them together and clearly identified as to what they are....vs random loose hardware that accumulates.
   / What size shear pin should I use? #5
Standard bolt 1/2"x 4" or 4.5" . Tractor supply sells them by the #.
   / What size shear pin should I use? #6
Replace it with one that fits tightly in the shear pin hole whatever size that might be. There should be no slop in the shear pin, a tight fit is critical
1989 AM General M998 HMMWV 4x4 Humvee Truck (A59230)
1989 AM General...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A59905)
2019 KENWORTH T680...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
Woods 1800 Batwing Mower (A59814)
Woods 1800 Batwing...
Toro Three wheeler sand pro (A56859)
Toro Three wheeler...
Deere 333E (A60462)
Deere 333E (A60462)
