What size shear pin should I use?
   / What size shear pin should I use? #1
atcNick
Longview, Texas
Still shopping
I have a 30hp kioti tractor and a 5ft house brush hog. Broke my shear pin for the first time and I’m not sure what size pin I should replace it with.
   / What size shear pin should I use? #2
If I remember right:1/4"x4" grade #2 bolt.Do not use grade 5 or 8.
   / What size shear pin should I use? #4
TSC sells a 4 pack of shear bolts and nuts that’s pretty cheap if you shop there. Comes in a retail pack with heat shrink plastic over cardboard so you can peel one off and then hang the remainder on a pegboard or toss in a tool box and have them together and clearly identified as to what they are....vs random loose hardware that accumulates.
   / What size shear pin should I use? #5
Standard bolt 1/2"x 4" or 4.5" . Tractor supply sells them by the #.
   / What size shear pin should I use? #6
Replace it with one that fits tightly in the shear pin hole whatever size that might be. There should be no slop in the shear pin, a tight fit is critical
ASSET DESCRIPTIONS & CONDITION (A59575)
ASSET DESCRIPTIONS...
2011 FORD F-550 (INOPERABLE) (A55745)
2011 FORD F-550...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
1607 (A57192)
1607 (A57192)
2016 DRAGON SAND CONVEYOR (A58216)
2016 DRAGON SAND...
