What size snow bucket - DS4510HS
   / What size snow bucket - DS4510HS #21
Nice bucket, jacques
   / What size snow bucket - DS4510HS #22
Just happened to see a snow bucket for sale in our local paper;3x3x7' for $300.00.Good deal if it is SSQA.I don't think I need one but the price is right.
How deep is that bucket Jacques? It looks similar to some of the buckets I've bee looking at.
We got 6" of snow that was so close to being rain that they couldn't call it. So it was very wet. with my current 65" bucket (yes, only 65" outside to outside, measured it) I think I could have pushed through it forever. I would get a pile that builds up in front of me and then that pile will stay about the same size as the extra spills off both sides. The problem is that it leaves a 5.5ft path so I need at least 2 more passes to get an 8' driveway clean. The 2nd pass does the other side but leaves snow on the part I plowed first. If I'm lucky, I can get that all up in the 3rd pass without spilling anymore. With a 7' bucket, I'm hoping to do one pass leavning 6" unplowed on each side of the drive. I won't worry about that. All the vehicles that need to get in and out are small. I have one drive that I measured at 7 foot at the narrowest part. The anthing over 7 foot isn't going to work.
So I think I'm goint to look for a good deal on a high volume 7ft bucket. At the same time I'll look for a deal on an 8' hydraulic angle rear blade. I have a 6' rear blade but not only is it short, but I think it may be to light for this tractor. Plus, I really want hydraulic angle. I'll use this for some dirt and gravel work each year as well.
So I guess the search is on! Hopefully I can find some local deals as good as your $300 bucket nybirdman!
   / What size snow bucket - DS4510HS #24
Ron,
In the pic. you can see the bottom of the bucket and it is 16in. deep so I add another 16 in or so. I made this extension with 3/16 T1 steel plate, 3in. X1/2 flat bar as cutting edge and 2in X 1/4 on the side to bolt the extension to the original bucket and underneath as stiffener and wear plates.
In the spring I take it off to work in sand or gravel.
Later I had install (not on the pic) a 6 in. X 5ft. on the back top to hold the snow when I curl back.
For me it suit my need's. For a Foton 254 it is enough.
Jacques :)
Nice work Jacques!
So I finally pulled the trigger and went with a Loflin Fabrication Snow/Liter bucket. I decided to go with 6 foot wide instead of going wider because I'm also using it in the woods to collect wood for the winter. The dimension are 38 inches deep by 27 inches high. Here's a picture on the tractor. Looks Long!
UNUSED SDLANCH SDLJC HIGH-END MOBILE JAW CRUSHER (A54756)
UNUSED SDLANCH...
2015 JOHN DEERE 1050K WH CRAWLER DOZER (A52705)
2015 JOHN DEERE...
Cat TH407C Telehandler (A53472)
Cat TH407C...
2018 CATERPILLAR CB24B SMOOTH DBL DRUM ROLLER (A52705)
2018 CATERPILLAR...
2022 CATERPILLAR 980 WHEEL LOADER (A51246)
2022 CATERPILLAR...
UNUSED WOLVERINE GB-11-72W 72" HYD GRAPPLE BUCKET (A54757)
UNUSED WOLVERINE...
