Changed the transmission fluid today--there was some water that came out before the oil, and the oil was in really, really nasty shape. I peeked in the filler cap and didn't see any rust inside, so I'm hopeing it'll be alright?
Also, the package from Just8n's arrived, so I replaced the temp gauge and proofmeter (the proofmeter cable seemed a bit too long though--it would only work if I unscrewed the coupler from one of the ends, but still left the cable end attached /forums/images/graemlins/confused.gif ). Going to try removing the cable from the original guide and seeing if it likes having more play.
The low point of the evening though, was changed the oil. I warmed it up, emptied the old oil, changed the filter, added new oil (straight 30, as recommended) started it up, watched the oil pressure build to 20psi, and, after the engine had stalled (still need to fix some ignition problems...), noticed an enormous pool of oil under the tractor. Tightened the nut on the oil canister (it had been on there really tight), added a couple quarts until the level had risen to a comfortable spot on the dipstick, and started it again. Another geiser coming from the canister /forums/images/graemlins/frown.gif. Removed it, found the gasket probably wasn't seated right, and put it back. Realized I was out of oil to add, and, even though it hadn't dropped to "Add more" on the dipstick (maybe a quarter inch above that line) I decided to call it a night. First stop in the morning after breakfast is gonna be someplace that sells motor oil. Hopefully the engine wasn't damaged and it won't gush tomorrow. If it doesn't, I'll finally be able to use it to do some actual work. /forums/images/graemlins/laugh.gif
soundguy: you mentioned that some had been converted to a spin-on filter. Hopefully it's still possible to do that? This evenings activities have made me want to give to the estate of the man that invented modern oil filters...
