Oil & Fuel What to do with 500 Gal of heating oil
   / What to do with 500 Gal of heating oil #11
^^^^ What Eddie said. I'd find a way to use it in my tractor. For all intents and purposes....... its no different than off road diesel.
zionview said:
You could look for a 500 gal tank with a dyke and transfer it to use for your 'Bota. It's not gonna get any cheaper.
Agree that the price is right. My usage is quite low though. I think I average one to two gallons a week. Meaning it will last me five years to go through it! Wonder if the fuel can be preserved for that long.
Were you on automatic fill?
Yes we were. And I told my wife to call them and say not to fill it. She forgot and they filled the thing a week later :(.
   / What to do with 500 Gal of heating oil #13
I decommissioned a fuel oil tank at my place and the fuel oil dealer came and pumped it out. He checked for water and then said they'd buy the fuel from me. I had 200 gal. and they paid me $4.00 a gallon. I ended up buying a diesel tractor a couple of months later; I wish I had kept the fuel.
   / What to do with 500 Gal of heating oil #14
Years ago My cousin used heating oil in His JD 350 all the time. He added some kind of oil for lubrication. If You wan't to know the combo, I'll call him.
   / What to do with 500 Gal of heating oil #15
amirm said:
2*Anyway, right before the remodel started, the oil company filled the darn thank and sent us the $1,200+ bill!
4* The general contractor is suggesting that we empty the tank and fill it with sand.
6*I hate to have to pay someone to dispose of that oil.
8*This was end of last year by the way, when fuel prices were cheaper than they are today.
10*Question is, what is the best way to use that fuel to power my BX-24.
12*I worry about how much cost and effort it would take to use that fuel.
In addition, the tank is right in front of the driveway and entrance to the house.
14*So I cant really put in a permanent pump and such and make the place look like a gas station :) .
2*Why did you let them fill the tank if you didn't want the fuel?
4*Dumb suggestion are you sure you want him for a remodeler?
6*Why would you want to pay somebody good money to take fuel you just paid $2.40 a gallon for then turn right around and replace it at $4.70 per gallon for your bx24?
8* so why replace it with today's almost twice as expensive fuel.??
10*Get a little ole $99 12 Volt diesel pump from northern tool and a water blocker filter and hook that up to the tank and use it in your BX24.
12*You saved $1150 bucks over the cost of that fuel today and you're worried about the cost of a pump filter hoses and some pipe fittings.
You're only looking at perhaps 200 or 300 dollars to set it all up.
You saved enough on the fuel to pay the 2 or 3 hundred and have hundreds left over.
What more could a guy ask for?
14* I don't think a little old pump about the size of a small electric motor and a filter slightly larger than an oil filter is going to make the place look like a gas station.
   / What to do with 500 Gal of heating oil #16
ampsucker said:
... once it's empty, fill it up with the cheapest fuel you can find and let it stay there.
amp
He only has $2.40 a gallon in this fuel for his tractor.
Where is he going to find diesel for less than that at todays prices.??
   / What to do with 500 Gal of heating oil #17
If you don't use enough of it each week, maybe you could offer to let another tractor buddy to help you use it up!!!
David from jax
   / What to do with 500 Gal of heating oil #18
Add 10 % cooking oil with the diesal for lubrication
As I explained, it was on auto-fill. We were originally going to keep the oil burner but later decided to switch to different heat. A week later we get the bill for the fill up.
What is so dumb about it? I hate to see that fuel sit there and start to leak later. As an interesting aside, his father was worked for a fuel distributor and it was him that told me I can use the oil for my tractor!
Until I post here, my only experience with old fuel was with boats. There, I had read that you had to pay companies to come and remove old diesel fuel from the tank.
I have looked into that. But as I said, I can't leave this stuff hooked up in front of the house. And I am thinking that connecting and disconnecting would make a mess with fuel dripping from hoses and such upon removal.
It is kind of hard to describe. But the house is at the bottom of the hill. Then there is the entry/driveway and right after that (10-12 feet) is the landscaped hill and right there is the tank. There is no way I can get away with putting anything permanent there.
Anyway, appreciate the detailed response. I hope to find a non-stupid way to deal with it :).
   / What to do with 500 Gal of heating oil #20
Why not have it excavated ,and moved around the rear. It could be on a cradel for tractor use. It must be done with care! how old is the tank?
2002 Ford F-550 Crew Cab Landscape Dump Truck (A56858)
2002 Ford F-550...
1997 Ford F Series (A57148)
1997 Ford F Series...
Bunker Rake (A59228)
UNUSED FUTURE VR39 39" HYD MINI VIBRATORY ROLLER (A58376)
UNUSED FUTURE VR39...
UNUSED FUTURE 3T HYD TILT BUCKET (A58376)
UNUSED FUTURE 3T...
Enerpac Hushh-Pup Hydraulic Power Unit, Model Per-132, Product Code B14880, 1/3 HP, 120 Volts, 1 (A59076)
Enerpac Hushh-Pup...
