What to get for major earthmoving
   / What to get for major earthmoving
</font><font color="blue" class="small">( It would sure be nice to see a picture of the proposed road area. )</font>
Here is a picture of the existing driveway (17% grade) up the front. The state requires that the first 20' be level, and then put in a couple switchbacks to lower the slope to 12%. All the trees in this picture will be taken out to allow for sitework. The steep parts are on both sides of the driveway.
Here is a profile shot showing the start of the slope that has to be cut away and the remainder left at a 1:2 grade.
Here is a shot of the backside of the hill. Most of the trees to the left of the center sandy portion will be removed for the road. I'm hoping that since it's a sort of ridge, I can come at it from the side and have fewer issues with slopes while using the machinery.
Here is a profile shot of the backside slope. It's a bit steeper than the frontside. /forums/images/graemlins/smile.gif
Here is a high resolution section of the survey plot I have for putting in the driveway. Notice the original driveway faintly in the background, to give you a sense of scale. There's a lot of regrading of slope indicated, too.
Finally, here is a topo map made from an aerial scan of the property. The driveway indicated is more or less as the existing driveway appears. That 470' peak (about 30' above the road) is the main source of all the fill that's got to move.
   / What to get for major earthmoving #47
Think I would consider a small cat to do a few days rough pioneering work to get a rough trail and then work out what you wish to do from there. You can move a lot of dirt if you are pushing downhill.
Also consider drainage and runoff.
Egon
   / What to get for major earthmoving #48
Nice Pics. IMO - you need to get a track loader. A wheeled tractor is just not up to this task. In your yearly formula, it appears you did not take the frozen winter ground into consideration. You best bet is to spend the entire budget on the largest track loader you can find. Complete all the rough work, no matter how long it takes and sell it at the end. You should easily be able to recover a minimum of 75-80% of the purchase price. Then buy yourself a nice tractor for the finish work. You will have a clean new ride and the grading will have cost about $10k +/- Just remember if you are new to this, take it slow. Small buckets at first. Keep the bucket as low as possible, especially on hills. Enjoy and good luck!
Egon,
I'm looking into renting a sampler of machines to see how they do; there's a steel track dozer on the list. I don't think I want to consider a rubber track machine with the number of stumps and rocks I'm going to be driving over and turning on.
The survey I have is four pages of details including drainage calculations. It even lists where to place the hay bales to prevent erosion during construction.
Everyone, thanks for the advice! I've got plenty of good ideas on how to proceed. I've got a guy coming in the next week or two to take the trees, and then the surveyor will be staking the entrance, which I've hired someone else to do (I'm not bonded for tearing up a state road).
-Dave
   / What to get for major earthmoving #50
I would not even consider a rubber tracked machine. Just a good dozer to get a trail in and go from there.
Sounds like you are far ahead of all of us on the planing stage.
Happy dirt moving! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Egon
2018 Chevrolet Equinox AWD SUV (A55758)
2018 Chevrolet...
1999 CLEMENT END DUMP (A53843)
1999 CLEMENT END...
Toro 880 Procore Turf Aerator Tractor Attachment (A55787)
Toro 880 Procore...
New Idea 6254 Round Baler (A50775)
New Idea 6254...
2025 SDLL30 Mini Stand-On Track Loader Skid Steer (A53421)
2025 SDLL30 Mini...
2021 PJ 16 T/A DUMP TRAILER (A55745)
2021 PJ 16 T/A...
