What to use in Ballast box
   / What to use in Ballast box #71
Wish I'd thought to use my dried out bags of concrete mix for my BB! Duh!
Guess I'll just fill mine with gravel, which I can always use somewhere on the drive when I get a better idea.
Still thinking about where to pick up some dense rednecks! Hey, yu all!!! The beer's over here!
GGB
You could have broken up the dried bags of concrete and dropped the chunks in the wet concrete in the ballast box as you were filling it. :mur: There goes the dried up concrete and you don't have to find a way to get rid of it!:thumbsup:
Tom:drink:
   / What to use in Ballast box #72
I made a box that is mounted on a standard carry-all. The inside dimensions are 40" x 32". It will hold 10 - 8" std wt (40# ea) concrete blocks per course. With 12" high sides two courses are possible, so that's 800# plus the wt of the carry-all.
The blocks are removable and might even be usable for your house or barn addition. Also, you can buy 'heavy wt' blocks at about 60# each or build the sides higher.
   / What to use in Ballast box #73
I found a JD box on CL for a good price, modified t to fit my needs. Scrap iron inside, galvanized tray (old grainery door) above the iron, chain saw sheath on one side & 2-tool tubes on the other. RR rail skids with 2" receiver tube for light towing. Have put in another set of 3-pt pins 5" lower to avoid digging-in when loading on my trailer. ~~ grnspot
   / What to use in Ballast box #74
What about Kryptonite?
Well, since Kryptonite is an imaginary substance, and imagination is weightless, that probably won't do much good.
Krypton is a noble gas, and air doesn't weigh enough to make any difference either. Krypton difluoride, sometimes referred to as Kryptonite, is a volatile, colourless solid; with a density of 3.24 g/cm^3. Volatile compounds probably aren't the safest things to use as ballast.
Wikipedia says that, "a form of the fictional mineral "Kryptonite" has been discovered recently in Serbia; it has been formally named Jadarite (after the region where it was discovered), molecular weight 221.63 gm. The composition of the mineral is sodium lithium boron silicate hydroxide, which is one element short of the description of Kryptonite in Superman Returns (the mineral lacks fluoride)" so I guess you could call that pseudo-Kryptonite. Anyway, it's kind of hard to obtain.
Also in Wikipedia is the Superman III (1983) formula for Kryptonite that is "a compound made up of 15.08% plutonium, 18.06% tantalum, 27.71% xenon, 24.02% promethium, 10.62% dialium, 3.94% mercury, and 0.57% of an unknown substance." However, this is obviously fictional as while Xenon, a noble gas, is known to form many compounds, is not capable of forming a compound with these particular elements.
   / What to use in Ballast box #75
I know this has been beat to death ...
I was planning on embedding head-size rocks in concrete in a 55gal plastic barrel. Rocks are free and plentiful around here and I can sell my crap iron and lead. Dr Zinj, what is the density of hard rock (not talking sandstone here). And if I get it to about 600-800 lbs I can always add rock, scrap iron, lead to increase the weight. And the density of cures concrete has to be higher than 2.4
   / What to use in Ballast box #76
I think I among the side of loaded tires and a box blade. You can always add some wight to your box blade if needed. I can't imagine the compactness being more of a value than the unbelievable usefulness of a box blade.
   / What to use in Ballast box #77
I'm in the same camp as you. My box blade weighs about 1,100 pounds, so it makes a perfect ballast box.
   / What to use in Ballast box #78
The advantage of a ballast box is it's very compact for the weight...much less likely to clip something (wall or vehicle) when working in tight areas. Also, of course, some of us have no need for a box blade.
   / What to use in Ballast box #79
That's exactly right Roy. Even though I have implements that provide great ballast, including a backhoe, when working in tight spaces with either loader or snow plow I like the ballast box. Also takes up less length on those lucky winter days when the tractor gets a spot in the garage.
   / What to use in Ballast box #80
GOPR2003.JPG My ballast bucket. About 650 lbs with room for more and tools/chain.
GOPR2004.jpg I imbedded a hitch to move the trailers & log splitter
(3) SHOP VACS ON PALLET AND MISC. (A58374)
(3) SHOP VACS ON...
2025 Stump/ Trench Bucket Mini Skid Steer Attachment (A56857)
2025 Stump/ Trench...
2025 Swict 84in Bucket Skid Steer Attachment (A56857)
2025 Swict 84in...
Case W7 Wheel Loader (A55272)
Case W7 Wheel...
METRIC DUAL CUT TAP & DIE SET (A58374)
METRIC DUAL CUT...
New/Unused 20ft Bi-Parting Iron Gate (Elk Design) (A57454)
New/Unused 20ft...
