What to weld rebar with for target frame
   / What to weld rebar with for target frame
Thanks. I'll keep checking craigs list for a stick welder. Right now I'm using two sawhorse brackets with 2x4's in them and a 2x4 cross beam which is holding 3 of the 500 3/8" brinell plates. It works well but is sort of large to bring to the range each time. Also, the lead and jackets of the bullets really chew up the 2x4 legs. Its easy to cut your hand if you aren't careful. I've been scraping the lead bits out but I still think the rebar stand would work better. It will be low to the ground so the plate is only several inches up. I think it will work and I get to play with a welder.
Now if I shoot it with my AR50 I know it probably won't hold. :)
   / What to weld rebar with for target frame #12
If I was welding rebar I would use O/A. Can do #3 to #5 in one pass if I bevel each end half way through and use mild steel 1/8" rod. For what you are doing it is not technical or structural to any extent. Any junk alloy w/the mild steel will mix and give a passable weld. With arc by the time I set up, get the leads hooked up, get rod out of the oven, hood on, and tack up, and do two or three passes i would have 4-5 O/A welds done as that rig is always ready by my bench. #4 tip is always on the torch.
Ron
   / What to weld rebar with for target frame #13
he is shooting at ar500 steel. I shoot at hardox 450 and my 30.06 308 7.62x54r wont even dent this steel at 100 yards. My 223 will do a little bit of surface damage. My buddy has a 270wsm that will punch a hole though 3/8 hardox. Now if he is using 500 i doubt my 223 will do any damage. If he stepped up to 1/2 only thing going to hurt it is maybe 300 win mag, or .338 lupa mag or 50bmg will go straight though.
   / What to weld rebar with for target frame #14
I believe that phosphorous is the only thing regulated in rebar unless it is weld spec rebar. I want to throw up when I see rebar bent into hooks for lifting. It is cheap for a reason...
   / What to weld rebar with for target frame #16
Brains, brains. Ha ha ha not really funny.
   / What to weld rebar with for target frame #17
I always took a second look before going up a ladder that was made with rebar rungs. :laughing:
   / What to weld rebar with for target frame #18
Man you ain't joking, I cannot understand why they do that. Had a safety guy tell me it was safer cause you won't slip. It was the best choice! Welcome to the world of the lowest bidder in the country that killed the Twinkie. :( on a positive note rebar is still great for concrete
   / What to weld rebar with for target frame #19
I've built hundreds of ladders, but can't remember building any that had rebar for rungs. But who knows, I've built so much crap in my life It's beginning to be all a blur now! :laughing:
   / What to weld rebar with for target frame #20
I had a safety guy ask me with a wise attitude, do you really think its smart to be smoking near those bottles! My reply was, YEAH WHY! IVE BEEN LIGHTING THE TORCH HERE ALL DAY! WHATS THE PROBLEM! He said, oh!, I didnt think about that, sorry! Theyre not that swift! LOL
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
KJ 20' Metal Farm Driveway Gate (A53314)
KJ 20' Metal Farm...
(2) POLY DRUMS (A52708)
(2) POLY DRUMS...
Bulk Lot of over 600 NEW Motorcycle Sprockets - 1980s to Present (A56438)
Bulk Lot of over...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
2018 Keystone Outback Super-Lite 330RL T/A Travel Trailer (A59231)
2018 Keystone...
