Oil & Fuel What trans fluid should I use in Massey Ferguson 135?
   / What trans fluid should I use in Massey Ferguson 135? #1
80sDweeb
Penfield NY
Massey Ferguson 135 Vineyard Diesel
1972 MF 135 diesel with 8 speed (no multi power) - what trans fluid (budget is a concern) should I use? And what would Tractor Supply carry that would work for me? I'm more likely to do that than to locate a Massey Ferguson dealer locally to buy pails of oil.
Scott in Brighton NY
   / What trans fluid should I use in Massey Ferguson 135? #2
Try posting this in the Hydraulics forum. Lots of great knowldge there.
   / What trans fluid should I use in Massey Ferguson 135? #3
Use the TSC fluid. It will do fine in your Massey.
   / What trans fluid should I use in Massey Ferguson 135? #4
The specification calls for M-1129-A, Permatran III or equivalent. COASTAL MULTITRAC TRACTOR FLUID meets M-1129-A and retails in western PA for $49 per 5 gallons at AutoZone. I've settled on it because of good performance in the range of temperatures encountered here in the mountains of southwestern PA. In NY, cold weather performance might be a consideration for you too. Hope this helps.
(18) WOOD PALLETS (A60432)
(18) WOOD PALLETS...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
8065 (A55852)
8065 (A55852)
2019 Dodge Charger Sedan (A59231)
2019 Dodge Charger...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
John Deere 1025R (A53317)
John Deere 1025R...
