Spudland_Dave
Veteran Member
Time for me to play devil's Advocate...
Doubtful we will see that...why would they need it? They already offer iMatch which pretty much takes care of this issue from the comfort of your seat. I know that I dont need that feature with my iMatch...
Hmmm realistically Deere priced themselves out of this one. I find with my factory mount kit/speakers with the Kenwood CD player I had installed that the sound is excellent...
The problem isnt the 3rd SCV...its working as it was designed...your using the 3rd SCV for a use it was never intented for. If you want constant oil back there you should have the Power Beyond setup installed...that is made to supply oil back there all the time as you would like.
Again, the machine is working as designed...if you needed that feature, maybe you should have gotten the eHydro instead.
By reducing the ROPS height, youd reduce its effectivness...Mebbe the problem isnt your tractor, but your garage door?
TCowner said:I would like to see a fender mounted switch on the back like the larger tractors to move the three point hitch up and down.
TCowner said:I think Deere could improve the sound system in the cab. Its decent but the factory speakers are just average and there could be two rear speakers as well. My original factory radio/cd player only lasted about 9 months. The Jensen replacement is a much better unit.
soulasphil said:a decent way of using the 3rd SCV, instead of the present lever which has to be held in place (unfortunately I only have 2 hands) or tied with a small chain or elastic band which regularly comes off when you are using it for several hours on end. Why it cannot stay on as long as you need it is beyond my understanding.
soulasphil said:slower A gears for applications needing rpms for hydraulic output and slow tractor movement.
soulasphil said:a lower ROPS that would fit standard garage doors. More generally, the tractor seems designed to operate in vast open spaces, without walls, garage doors, low branches hitting the lights or bushes catching the hoses under the tractor, etc. An effort should be made to make it more practical.
