What would you change?
   / What would you change? #31
I would add a second hydraulic cylinder to me FEL Bucket and move the cylinders to the FEL arms like the B, L, and M series.
It appears that since I added a toothbar I could a higher breaking force to help dig up rocks.
   / What would you change? #32
Position control for the 3 pt. would be nice on mine. I also like the auto connect deck that's available on the Deere 1026R...or at least it will be when they finally start to deliver them. And, of course, the 3 range hydro.
   / What would you change? #33
It's a level that you push down by foot but must hold down.
Unlike a car or truck, the differential lock is a true lock. If it were held down all the time, you would build up tremendous stress in the axles when going around curves or hard turns. Best case you would tear up the ground, worse case you can break the axle or differential. The designers really want you to not be able to keep the axle locked.
   / What would you change? #34
I'd like a fuel tank and hydraulic system that is easier to fill on my JD 4300.
I've added the custom lights, radio, cigar lighter, gun case, chain saw holders, booster cable plug, roof, etc. I'd rather do these things to MY specs, where I can reach them, than have some engineer decide the cheapest place/way to do it....
I can't relocate the fillers however as the designers/bean counters got to them first.
On the other hand, my BIL wishes his little MF didn't need two right feet to operate the steering brakes and go pedal at the same time....
   / What would you change? #35
I ran a spool in my race car without problems. I have a 2000lb side by side that has a lever that locks in the rear then push it further and it locks in the front (talk about hard to steer). Sure if you try and drive on pavement it can do damage but like anything else if you read the manual it tells you not to.
Usually when I need to lock the rear diff I'm also trying to do other things like adjust an attachment so it's not digging as much or if going up a hill trying to pick a good line. Either way I would rather just push a lever than use one foot to hold a diff lock lever down. Of course when you are holding that lever down now you are kind of lifting yourself out of the seat, it doesn't take much on the newer tractors for the cut off to shut your engine down.
   / What would you change? #36
:eek:I would not change a thing, because I figure that Kubota has already built mine with years of experience and engineers that know the intended uses of this machine. Like others above, one can customize superficial things to ones own preference, but even then, a tool box....extra set of lights...etc. could create their own problems for accidents or unusal wear. If I wanted more power, speed(s) etc., I'd buy the appropriate model.
   / What would you change? #37
JD 3320.... Z-gate for shift lever so it is easier to know what gear I'm in. TOOLBOX, one big enough to put stuff in. Standard rear remotes. Finally self timing glow plug switch.
   / What would you change? #38
Kubota BX-23. Curl function on the FEL, I would change the valve so that the regen on the dump is at the far right past the detent. With a fully loaded bucket, the dump is so fast that the bucket bangs against the stops much too hard. I have had to reweld them on the loader arms. Either that or a cushioned curl cylinder. I would also like to have steering brakes for back dragging with the FEL.
2020 Freightliner Bucket Truck (A55973)
2020 Freightliner...
1996 International Semi (A59814)
1996 International...
2019 TerraGator 7300 Spinner truck (A56436)
2019 TerraGator...
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
2006 JAYCO JAYFLIGHT 30' TYPE CAMPER (A58375)
2006 JAYCO...
2022 Can-Am Defender XT HD10 (A59814)
2022 Can-Am...
