What would you change?
   / What would you change? #21
Beep!!! Beep!!! A horn !! So my wife will know I need another beer,,:D
   / What would you change? #22
I would like to see Deere use steel insted of plastic. I would like to see rear hydralic outlets standard equipment. I would laso like to see more lighting, I have added more lights to every tractor I have owned.
   / What would you change? #23
How many times have you wanted to hop off, but you have to step on the brakes, lock the parking brake, put the tractor in neutral, throttle down, get off grab the one thing and then reverse the whole process.
Tell me about it...:confused2:
   / What would you change? #24
Have you guys noticed that just about everything that you want is available, for a price. Just need to get a different make or model and spend more $$$$$$$$$.
   / What would you change? #25
I would like to see the rear diff lock be a hand lever or a foot lever that locks in position.
   / What would you change? #27
But is there a model that has EVERYTHING we want (including what we already have and like)? ;)
   / What would you change? #28
Only a couple things I'd like on mine. One is already on the 2320 and 2520, more detailed 3ph control. 2nd would be a built in remote hydraulic spigot for the rear. Think my 4010 has it, just missing the spigot. Guess there's a kit for it.
One thing they ought to have is a built in hand pump to pump fuel from a container on the ground to the tank. Our old 240D had a built in hand pump that allowed priming of the system once a fuel filter was changed. This same kind of hand pump would work fine to pump fuel from a container to the tank. Heck, they could easily have a 12v one.
Ralph
INTERNATIONAL FLAT BED TRUCK (A52707)
INTERNATIONAL FLAT...
2012 INTERNATIONAL PROSTAR+ (A58214)
2012 INTERNATIONAL...
1978 Gray 48RM Vertical Boring Machine (A59213)
1978 Gray 48RM...
WINCH CABLE DRUM (A58214)
WINCH CABLE DRUM...
2023 FORD F-150 XL CREW CAB TRUCK (A59823)
2023 FORD F-150 XL...
2021 MacDon FD135 Flex Draper - 35' (A59814)
2021 MacDon FD135...
