Whats the Rachet Noise ?
   / Whats the Rachet Noise ? #11
Well, as you told the story, the noise occured when the log jamed and the cable drum had stopped turning.
If the cable is not being spooled, the drum is not turning.................
OK - I guess I need some help understanding what you are trying to say.
You say yours does this often? And you attribute it to the sprocket.
I'm was thinking the pto was turning but clutch was slipping and the cable was positioned just right to skip along the turns because it was not wound turn to turn on the spool and had lots of pressure on it. Wouldn't you think that if it was the sprocket that it would skip anytime I had that much pressure on the clutch ?
   / Whats the Rachet Noise ? #13
Sorry, no. My winch only did this once this past year and I was "pushing" it....several big logs, pulling up a hill, stump hangup.
It is an old winch but I rebuilt it a year ago last summer.
Before I rebuilt it (new thrust and input shaft bearings) it would do this more often (maybe 3 or 4 times the previous season). The input bearings were quite bad and I believe that made tightening the chain tensioner rather ineffective.
Since the rebuild, it has done this only once. BTW when I rebuilt the winch I also retensioned the chain, but I erred on the "not TOO tight" side of the equation.
"It" is a loud ratcheting sound accompanied by some attention getting vibration.............and the cable is not moving. Hope that is clearer.
PS I find that when I do get a cable bind it is because I allowed the tension on the cable to vary to widely over a short period. IE if I take up the slack easy...........and then ease into the tension on the clutch lanyard, I generally do not get cable bind on the spool.
OK thanks - That all makes sense. I guess I'll never really know what it was unless it starts happening alot. I dont know how loud it was but I had on hearing protectors (muffs) over a hard hat liner that covered my ears and had no trouble hearing it. I let the lanyard go immediately. Just prior I was pumping the lanyard to try to bounce the log free (I know - not good) so the cable was cycling between tight and slack which would make it whip around on the drum. As you point out that can cause a bind.
   / Whats the Rachet Noise ? #15
Ok, understood.......... One other bit of info you might find useful. Farmi makes their owner manuals available on the internet. You can down load your model manual and it will tell you exactly how to tension the chain........
I bet if you check it, the chain is not quite tight enough. I know mine is not, and it is the dirst thing I will deal with in the spring.
My winching season is over, thankfully.
   / Whats the Rachet Noise ? #16
Hello Gordon,
I was wondering how often you oiled your cable?
Hello Gordon,
Never ?? From your question I assume that isn't good. My manual says to keep all oil and grease away from the drum so it doesn't spread onto the clutch so I have never oiled the cable.
I will check the chain tension specs and proceedure Dead Horse - Thanks.
I found the tension adjustment instructions in my winch manual. I am sure you are right and it is looser than it should be after nine years of usage.
I will tighten the chain before I head out this morning. Looks simple enough.
I enjoy the winter woods. The work is plenty hard enough so you don't get cold. The snow makes things a little slower though.
gg
UNUSED FUTURE 16" HYD AUGER (A52706)
UNUSED FUTURE 16"...
2024 HURRICANE GF480 - 48" ROTARY DRUM SCREEN (A52706)
2024 HURRICANE...
2014 Lamar Pipe Trailer (A60460)
2014 Lamar Pipe...
Deere 410L (A53317)
Deere 410L (A53317)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Case-IH 180 Magnum (A57148)
Case-IH 180 Magnum...
