StoneHeartFarm
Veteran Member
Re: What\'s up with this roof?
Muhammad
Seeing your interior set up, I would expect moisture is a bigger culprit than heat. Do you know what kind of insulation was used? Foam or fiberglass? I've seen both. Foam is probably slightly more common around here. Basically, they laid the ceiling boards, glued foam to the backside and then nailed the sheeting directly to the foam, using long nails that would reach through and go into the trusses/rafters. There are usually at least some light rafters added above the finished ceiling for support for the roof sheathing. If moisture is building up in those nailer rafters, that could account for the ridge no matter how the sheating was installed, since wet pine has a pretty good expansion around its girth.
Also, have you determined yet that the roof is sheathed with plywood, or with something even more engineered like OSB (a very common material in this area)? OSB really doesn't like water and will crown along its edges fairly easily.
SHF
Muhammad
SHF
